H.I.Ds what do i need?
Old Dec 16, 2010 | 08:20 PM
ChaseACarpenter's Avatar
hey guys i am wanting to get some 30,000k hids for my projectors, but i noticed when i installed them it said (no hids allowed) one guy told me i need to Get a wiring harness made of 10 or 12ga wiring when you buy the kit and i will be fine, im not exactly sure what i need maybe this? Really apprciate some help, http://www.ioffer.com/i/Xenon-HID-Wi...ector-70886501
Old Dec 16, 2010 | 08:25 PM
Old Dec 16, 2010 | 09:03 PM
illness95's Avatar
they make 30,000??? news to me
Old Dec 16, 2010 | 09:44 PM
dirtyd88's Avatar
30,000K is stupid. no offense. You won't be able to see anything, causing other drivers and yourself the risk of harm, and the glare produced from that color will do the same as mentioned above.
Old Dec 17, 2010 | 12:01 AM
well i think they look awsome guy had um with clear headlights looked amazing might not be good for driving vision but o well, they are a 30,000k deep blue hids, i think like the 10,000k looks stupid cause its more white than blue i geuss i just like the blue color
Old Dec 17, 2010 | 12:09 AM
ford4life.'s Avatar
Do you have projectors? If not get some. But don't do 30k that's just stupid
Old Dec 17, 2010 | 12:19 AM
yeah i have projectors thats why im askin about the wiring harness thing, cause it has a lil sticker that says (no hid allowed) ON BACK so i assume i need the wiring harness just not sure which one to buy? Also, i like the 30,000k look.... go good with my white led bar and halo rings
Old Dec 17, 2010 | 12:54 AM
Buxton91's Avatar
I think you need to research that color hid some more. i highly doubt your gonna pleased with it.
Old Dec 17, 2010 | 11:19 AM
dirtyd88's Avatar
30,000K is purple. Not blue. Just do a google search an you will see the color.
Also, WTF is the point of getting HIDs of that color, then saying you don't care about the driving aspect? Unless your truck is a trailered show truck, DO NOT put anything over 10,000K your headlights if you plan on being able to drive still.
As the reason your lights say "Do Not Use HIDs" is because the projector lens is most likely a composite material, and not true glass, and will therefore deform under the generated heat from the bulbs.
Not trying to be a douche man, but it this kind of stuff that give HIDs the bad rep they have on the streets.
Old Dec 17, 2010 | 03:29 PM
migdaddy's Avatar
what a fool.
Old Dec 18, 2010 | 12:02 AM
Raptor05121's Avatar
hey guise I just got some 100,000K HIDs! They are ultraviolet/black!
Old Dec 18, 2010 | 02:47 PM
ford4life.'s Avatar
I'd run em. Haha.
And the only good way is to do a Retro fit. Look in other mods section above other powertrain.
Old Jan 26, 2011 | 01:05 AM
MRyan's Avatar
actually guys 30000k realistically doesnt exist as far as kelvins in hids go, the lumens out put is to low, this is just another dumb japanese mix up in creating hids, I had a pair claimed to be 10000k hids but in the box it said 4300k just another international screw up between trade markets. Ive heard about 50000k where it glows green and has nearly 0 output, but I doubt there even HID's to be able to produce the green light it has to be a black tinted halogen. anyways your wiring harness is fine, the ballast draw less power than halogens, ballast run at about 35watts while halogens run at about 45watts, the ballasts just give the low power a little more punch when they hit the igniters in the bulbs. So your fine, melting harnesses is a myth, people just aren't connecting them correctly. my buddy has had HID's in his Honda for 1 year and nothings happened, and Hondas aren't built a rough as a truck so its pretty self explanatory.
Old Jan 26, 2011 | 10:10 AM
dirtyd88's Avatar
Your correct, 30,000K doesn't naturally occur.
But you can have a 30,000K HID bulb. All it takes is tinting of the bulb either by film or during production, with the right color, and boom, you have a stupid HID color.
Old Jan 26, 2011 | 02:50 PM
MRyan's Avatar
yeup but say goodbye to the longer life, once you tint any bulb the heat is kept inside of it and it burns out the bulb much faster. Especially with halogens where they use about 20% energy for light output and 80% for heat
