FAQs: Halogens v HIDs
Old Nov 15, 2010 | 04:51 PM
planehunter's Avatar
So, bottom line is that we "should" stay with DOT approved systems for the best quality?
Old Nov 15, 2010 | 05:04 PM
BaseballBabe's Avatar
Originally Posted by DirtySCREW
Mods...PLEASE make this a sticky!!! Thanks again Raptor----DirtySCREW
I agree. This really helped especially when I by my truck. Thank you Raptor...
Old Nov 15, 2010 | 06:13 PM
Jaak's Avatar
Great write-up!!!:thum bsup:
This is the reason I stick with DOT bulbs and major manufacturer such as Phillips, Ostrom, Narva to name a few.
Old Nov 15, 2010 | 06:14 PM
NCSU_05_FX4's Avatar
Here's the link to this thread in the "How To" section...
https://www.f150online.com/forums/ar...ns-v-hids.html
- NCSU
Old Nov 18, 2010 | 03:29 PM
great write up Raptor
Old Jan 28, 2011 | 11:15 AM
Raptor05121's Avatar
bump
Old Feb 2, 2011 | 03:04 PM
bump for more information.
added fog lamp information. added fog lamp birds-eye view and low, high and fog lamp output pictures in comparison to post #1.
Old Feb 2, 2011 | 03:15 PM
camopaint0707's Avatar
pretty good write up
Old Feb 2, 2011 | 03:21 PM
bump. added HIR bulbs to write-up and included more pictures.
Old Mar 10, 2011 | 10:35 PM
muddy99's Avatar
OKAY SO THE QUESTION I HAVE IS I WOULD LIKE A SET OF RETO FIT PROJECTOR HID'S whoops caps but back to my point is there anywhere on the web i can order a pair that have very good quality... i want some hid's because i do a lot of night driving and i had hid's in my 90 f150 and they worked awesome yeah i did get a good bit of flashes and they where bi xenon so i would flash highs back but point being i dont want to attempt to crack open a set of lightning headlamps and end of scraping them. and noone around my town is will to put their name on a project like this so i guess i need some help...
Old Mar 11, 2011 | 02:12 AM
visit www.theretrofitsource.com
I used the FX-R stage III kit for $320. If you have a dremel, its super easy. just cut away a little bit and keep putting the projector in, see where you have to trim some more, etc. its not hard at all, just time consuming.
Old Mar 13, 2011 | 06:15 PM
credurdead's Avatar
I found these on Ebay 2 years ago for around $135, I liked the black headlight with the halo, had no ambition(or money) to go the HID/Xenon route, but kudos to those of you who do it the proper way and don't blind the crap out of the rest of us on the road...The punisher emblems were just for fun and look sandblasted on during the day
Old Apr 13, 2011 | 07:58 PM
atr04screw's Avatar
I would like to get some HIDs, but I'm not sure exactly what I want to get. I was thinking about getting a set of projectors and putting ~5000k HIDs in them. Would this work good? I know the retrofit would be the best, but I dont have the money nor the ***** to cut into a set of headlights.
Old Apr 14, 2011 | 12:36 AM
ELVATO's Avatar
This would probably be best in a separate thread, so as to no clutter this FAQ thread.
How much were you looking to spend on "projectors" + HIDs? Depending on how much, it might just be better to save a bit more up, and do it the right way with proper HID projectors.
By "projectors," I take it you mean aftermarket headlights with projectors in them, usually found on ebay? Generally, and depending on how much they are, it could range from decent halogen projectors with halfway decent cutoff with HIDs, to craptastic output. I've seen people on here post output pix of some aftermarket projector headlights, and even with HIDs, it seemed like you'd get more light shining a flash light in front of you...
Old Apr 14, 2011 | 01:57 AM
Like I said in my first post, those cheap projectors utilize a crappy designed reflector bowl and probably a cheap plastic lens. Not to mention halogen projectors in main have a MUCH more narrower beam than xenon projectors, as you can see here- and these are OEM Valeo 3" halogen Fresnel projectors offered on Toyota's flagship Avalon and Solara models!
And putting PnP HIDs in a halogen projector is asking for trouble. Just save the $$$ and do a retro. It really isnt hard. Its just time consuming. I'd rather do another retrofit than change a set of spark plugs its that easy.
