02 Blend Door Repair
Old Sep 6, 2015 | 02:49 PM
02SUPRCRUE's Avatar
I'm looking for a complete set of instructions on how to repair/replace the Blend Door and Actuator.
And before everybody jumps and says use the search feature, I have. I found Quentin's instructions but the part where the whole dash comes off is missing. I also saw the guy in SC who posted videos on YouTube who does the repair in 3 hrs. If that is a true price and time, it would almost make a road trip form PA worth it.
Any help is greatly appreciated.
02 F150 Super Crew Lariat FX4 White & Silver
5.4 /w Roush Cold Air Intake & K&N filter
3.55 LS
MagnaFlow Cat Back
MagnaFlow Hi flow Cats
JBA Silver Cat4ward Headers
Rancho RS9000XL's
Rancho Steering Stablizer
Hellwig Rear Anti Sway Bar
Lightning Tails
Outland Sport Bumper Guard
Hella 550's
Silverstars
Superchips 9100 Micro Tuner c/o Troyer Performance
Underdrive Pullies c/o Troyer Performance
Mag-Hytec Trans Pan
Old Oct 25, 2015 | 02:59 PM
99duckey's Avatar
Did you ever get complete instructions or fix yours? I found another link running into the same issue as I am....the heater treater video is incorrect for 02 super crews. I can't get the duct out of the way? I'd appreciate your feedback.
Old Oct 26, 2015 | 07:42 AM
02SUPRCRUE's Avatar
99
No, unfortunately I have not found complete instructions. I did figure out that the blend door is not my issue. I believe my issue is with the EATC or the door that controls which duct the air comes out.
3.55 LS
MagnaFlow Cat Back
Rancho RS9000XL's
Lightning Tails
Hella 550's
Silverstars
Mag-Hytec Trans Pan
Old Oct 5, 2017 | 05:34 PM
darknessmatters's Avatar
anyone still have a copy of the 97 f150 service manual? I know this thread was from a few years back. If not thats okay, I'll just get something from alldata or ebay. Just thought i would try with you guys first.
Old Oct 5, 2017 | 06:23 PM
You found the other thread, replied there.
Old Oct 5, 2017 | 08:16 PM
Roadie's Avatar
If anybody needs instructions watch this. There are several parts.]
Old Dec 19, 2017 | 05:34 PM
Paco Flores's Avatar
You can find it in the Ford page with your vin, this is the link that i use to the spanish version, i don't know if is the same link for inglish version https://www.ford.mx/owners/owner-manual/
Old Dec 19, 2017 | 09:46 PM
Paco, he wants the service manual, not the owner's manual.
https://www.f150online.com/forums/19...ir-manual.html
Post #99.
Old Dec 25, 2017 | 11:33 AM
black sheep's Avatar
If it is not blend door
Just fixed heater/defroster/panel controls on '03. Saw lots of diagrams on electronic controls, with o-rings in them drying out. Other common issue was vacuum loss on line from between bat and firewall. Mine was vacuum loss due to mouse damage.
sorry, murphy's law, can't find any of the links now.
Old Dec 26, 2017 | 08:49 AM
projectSHO89's Avatar
The temperature blend door is electrical, it cannot be affected by vacuum leak issues.
Old Dec 26, 2017 | 08:56 AM
Just went back to where he stated it was not the blend door, and most likely with the controls for the floor/dash/defrost and saw the original thread is 2 years old. Guessing he got it fixed by now anyway.
Old Oct 17, 2018 | 02:47 PM
Jess Anderson's Avatar
Blend door actuator replacement
Hope this helps someone. You can access the actuator by rotating the duct that sits below the actuator. On the driver's side of the front of the duct, there is a corner piece that prevents rotation. If you saw off this corner piece, the duct can be rotated by pulling on the passenger side of the duct.This moves the duct out from under the actuator, allowing you to access and remove the actuator.
You do have to remove the electronics belle below the duct and a strut on in front of the passenger side of the duct first, but this is simple to do.
Note that although the actuator hha four areas for attachment with screws, only three are used. The forward, driver's side attachment site does not have a screw on it.
​​​​​​​But always check the temperature control **** first as it may be cracked at outta attachment site (I realized this was my problem AFTER I replaced the actuator)
