hot air only
Old Jan 20, 2015 | 02:02 PM
Texaslax22's Avatar
hot air only
i have a 2001 f150 with the 4.6. I was driving down the road when all of a sudden my ac started blowing through the defrosters when id accelerate and then switch back to the panel when going at a constant speed. I checked the vaccum lines and nothing is disconnected or cracked. And now it will only blow hot air through the defroster all the time. Still no cracked or disconnected lines.
Old Jan 20, 2015 | 02:13 PM
thelariat02's Avatar
Keep looking for a vac leak because that's the problem.
For those year vehicles it is common to have vacuum leaks in the evap lines behind/below the battery box.
Old Jan 20, 2015 | 02:50 PM
ooops! Thought this thread was about kingranchcoy!
Old Jan 20, 2015 | 03:08 PM
Get it together
Old Jan 21, 2015 | 01:10 PM
Texaslax22's Avatar
so i should only look around the battery box? it wont be anything into the dash? I dont know much about this stuff
Old Jan 21, 2015 | 01:15 PM
Behind the battery is the most common, but not the only place you should look.
I believe there is an O-ring in the HVAC controls themselves that goes bad.
Old Jan 21, 2015 | 01:22 PM
There are hard plastic vacuum lines behind the battery that get brittle and break.
Old Jan 22, 2015 | 01:35 PM
Texaslax22's Avatar
how much am i looking at spending for either the lines or the o-ring? possibly if a shop since i dont have much time anymore
Old Jan 22, 2015 | 01:44 PM
Broken lines behind the battery are usually easy, you can cut the bad section out and splice with standard vacuum hose. Cheap and not time consuming.
