Thump from AC
Old May 16, 2010 | 10:00 PM
wreedKR's Avatar
Thump from AC
My blend door resets itself every once and a while. I will lose cold air for a few seconds, hear a thump then cold air returns. This is on my 07 F150 with auto climate control. I do have the updated actuator.
Anyone?
Old May 19, 2010 | 12:51 PM
wreedKR's Avatar
Anyone?
Old May 19, 2010 | 11:13 PM
wreedKR's Avatar
OK I think it has something to do with coming to a stop and taking off again, the door always seems to clunk when I do that.
Old May 21, 2010 | 12:57 PM
Tumba's Avatar
It sounds like you probably have a vacuum leak somewhere. When you open the throttle vacuum pressure always drops. When you let off the throttle it always increases.
The most likely place for the leak is where the little vacuum line goes through the firewall right behind the battery. The fumes the battery gives off always decay that hose first. If the leak isn't there, just keep searching the vacuum lines until you find it.
Old May 21, 2010 | 01:09 PM
wreedKR's Avatar
It is a 07 I am having trouble with, all the AC blend, mode doors are electronic and not controlled off vacuum now.
Old May 21, 2010 | 01:35 PM
Tumba's Avatar
I didn't consider that, but have read it before. I have no experience with those. But it is odd, that it is the exact same symptoms. That's another thing that makes me go Hmmm!
Old May 28, 2010 | 11:31 AM
wreedKR's Avatar
Bump
Old May 31, 2010 | 06:34 PM
wreedKR's Avatar
Bump
Old Jun 23, 2010 | 04:20 PM
wreedKR's Avatar
Bump anyone?
Old Jun 26, 2010 | 01:03 AM
ricofalltrades's Avatar
There is a TSB in regards for a grinding noise when air flow changes. I do not know if that would work for you but the TSB number is 08-8-9.
Old Jun 26, 2010 | 11:16 AM
wreedKR's Avatar
Yes I have read that one and applied fix, not the problem I am talking about though with the random thumping from the ac system upon acceleration.
Old Jul 6, 2010 | 09:56 PM
wreedKR's Avatar
Bump. I think now it could be the air inlet door, but i still dont know.
