please help electronic climate acting up?
Old Dec 8, 2009 | 08:37 PM
davidshick2's Avatar
I have a 05 f150 lariat wiht the electronic climate control. My problem started to day usually my heat is really hot. Well today the temp came to normal range but continued to blow luke warm kept trying all day to get it to work. finally turned a/c on down to 60 and recirculating on let it run for a min then turned heat to 90 and it worked fine. Would this be the electronic climate control? I am lost please help.
David
Old Dec 8, 2009 | 09:26 PM
radar's FX4's Avatar
dave, my 2008 was doing the same thing about 6 months ago and when i took it to the dealership, they told me the "actuator flap" (something that opens and closes somewhere inside the dash) was malfunctioning and installed a new one and since then it has been great.good luck.
Old Dec 9, 2009 | 05:57 AM
thanks radar I will take it to ford as soon as I can. Do you remember about how much they charged or were you under warranty? Thanks again
Dave
Old Dec 9, 2009 | 06:16 AM
Windsor's Avatar
There is a TSB on the actuator motor. There are a few threads on it in this forum. Even if you're out of warranty the part is only $25 and it's a half-hour job. I changed mine because I didn't care to have my local dealership rip into my dash.
Old Dec 14, 2009 | 08:20 PM
dave, i agree with windsor. mine was covered under warranty and i was out the door in like 30 minutes. they are probably gonna stick you with the $90 an hour labor rate though.let us know how it comes out.
Old Dec 27, 2009 | 11:35 AM
Thanks guys I will buy the part and do it my self. Sorry it took so long to reply lost power and everything here for a while mountains are so unpredictable.
Thanks again!
