knocking
Old Mar 24, 2009 | 07:52 PM
Stephen87's Avatar
knocking
I have a knocking sound coming from my ac compressor any idea what it might be. I also replaced it less than a year ago
Old Apr 15, 2009 | 09:23 AM
torkum's Avatar
If you used a remanufactured compressor thats probably the problem. Should have a warranty if less than a year on the replacement.
Old Apr 15, 2009 | 04:41 PM
Stephen87's Avatar
Yea thats what a figured I have about a month left I need to take it off and replace it do you or anyone know how to drain the whole thing
Old Apr 15, 2009 | 05:24 PM
torkum's Avatar
Are you talking about draining the oil from the compressor or the fridge from the system?
Old Apr 16, 2009 | 09:28 AM
escortlvr's Avatar
Gotta watch those "warranties" if you replaced the compressor and don't have a reciept for the receiver/dryer and the expansion valve/orifice tube they will likely not give you a new one. Also tell them you flushed the system when you replaced the compressor...just a hint
Old Apr 17, 2009 | 02:49 AM
Stephen87's Avatar
I know I used to work at O'reilly auto parts so I know all the loop holes in the warranties department and I also bought them all at the same time.
and as for the draining I meant the refrigerant
Old Apr 17, 2009 | 03:04 AM
jrfonte's Avatar
most people and places that do the work want the refrigerant captured rather than just cracking a valve and releasing it. you can probally take it to a place that does the work and get them to extract it for a small fee.
Old Apr 17, 2009 | 03:17 AM
JJDH's Avatar
did u replace youself? the refridgerant must be recovered
did u vaccum the lines with a vaccum pump before recharging the system?
if u had air or moisture in the system, it will cause compressor failure.
are u low on refridgerant?
Old Apr 17, 2009 | 02:42 PM
Stephen87's Avatar
I did not replace myself
yes it was vaccumed
I dont know if I am low, I need to check
