A/C locked up, can it be bypassed?
Old Aug 27, 2007 | 03:04 AM
kaweloka03's Avatar
Unhappy A/C locked up, can it be bypassed?
My 1997 4.6L A/C compressor seized and the truck died.
Can I get a belt for a non A/C 4.6L and bypass the compressor?
I read that the tentioner for the non A/C is ribbed and the A/C tentioner is smooth. If I can bypass the compressor, do I need to change out the tentioner to a ribbed wheel?
Old Aug 27, 2007 | 09:57 AM
Yankee7985's Avatar
If your complessor is locked-up, the clutch should still turn. Sounds like your clutch shorted and needs to be replaced. You should be able to get a shorter belt.
Old Aug 27, 2007 | 03:32 PM
zziggy's Avatar
I have the NON AC tensioner and belts around here somewhere. $75 for both.
Your Compressors CLUTCH bearing must be bad, as a locked up compressor only causes problems when the AC is on.
Unplug the Clutch Cycling switch on the Accumulator to keep the Compressor from engaging.
Old Aug 28, 2007 | 07:14 AM
kaweloka03's Avatar
Thanks for the advice, I found a shorter belt will work, but I have to change out the tensioner to a ribbed type that pulls the other way
Old Aug 29, 2007 | 04:54 PM
zziggy's Avatar
I have the NON AC tensioner and belt around here somewhere. $75 for both.
These parts came off of a NEW F150 that was built without factory AC.
They are new truck take-offs, and the correct parts you need.
