Temperature Selector Problems '99 XLT
Hey guys. I'm having problems with the Temp selector **** on my '99 F-150 XLT. If I turn the **** to change the temp on the HVAC system (manual adjustment, not electronic) the **** "slips" and the temp doesn't change. I've pulled the **** off and it seems to be OK on the back. If I turn the **** really slowly, it will adjust the temp, but it's kind of annoying. Anyone else have this problem or any ideas on fixing it? The truck had an aftermarket AM/FM/CD unit installed just before I bought it last month. Could the installers have messed up something with the adjuster (it's located just below the stereo opening). Thanks in advance. Tracy
Hmmm I have a 99 XLT too and just started having the same problem... of course my A/C is also only blowing warm air too, but thats another problem in and of itself. My adjuste **** looks fine in back too... anyone have any suggestions?
Thanks!
Thanks!
Make sure that there is not a small thin crack on the inside of that ****.. I have seen this numerous times.
If your **** is good and your problem still persists, then it is probably the switch itself..
Good Luck
FordMasterTech
Good Luck
FordMasterTech
I am unsure of the price of the switch. I think it may be about $30 but changing it out is a breeze. just pull the bezel around the radio out and remove the four 7mm or 9/32 screws holding the switch assembly in. Disconnect all the wiring and vacuum harness on the function selector switch and then remove the **** off of the temp switch. Remove the screw holding the switch in place.
That's really about all there is to it as far as the replacement procedure goes,. If you need some more help, let me know.
Good Luck
FordMasterTech
Good Luck
FordMasterTech
well, I double checked the **** today and it had a hairline crack (two actually) in the back of the ****. I swapped it out with the one on the fan selector switch (as that gets used much less often and seems to have less resistance). Anyway, it seems to work fine. Thanks for the help. Tracy
Re: Compressor
Compressor was coming on for roughly 3 seconds and then cycling on/off. I checked low pressure side and was getting fluctuating psi readings everytime the compressor came on, so I added a can of r134-a and noticed that every time compressor cycled on it was staying on for slightly longer. Decided refrigerant was low...
Now 36 oz of r134a later and the compressor is staying on and A/C is blowing cold air. I suppose I have a leak somewhere, and hopefully this leakstopper refrigerant sealed it. PSI reading on the low end now is showing about 25 with the compressor running. Is this still on the low side?
Any other thoughts or ideas? Thanks MasterTech!!
Ryanweb:
It sounds like your low pressure side is reading in the normal range. What is the high pressure @ normal engine operating temperature and what is the ambient temp (surrounding air temp)?
Probably was low on 134.. But I would not recommend those sealers in a can.. I have heard reports through MOTOR magazine, as well as other manufacturers that strongly disapprove of the method of "sealer in a can"..
FordMasterTech
FordMasterTech
Thanks!
Jeff
Re: Stiff temp control
My temp control **** has done this exact same thing for over a year on my '98. The **** probably has a crack in it, but I would like to solve the problem which is a tight cable. I've talked to a few dealers, and they said to reinstall a new cable. I haven't even begun to start this project. Once I get the cable moving, it seems to loosen up a little. Either way, it's annoying, and Ford should have done something about this.
Air Temp
My Problem Is That My Air Changes For Cold To Hot. I Can Hear A Door Close When It Does This. I Can Turn The System Off The Adjust The Temp Selector Back And Forth, Then Turn It Back To Ac And Sometimes It Works Sometimes Not. Also When It Is Blowing Cold, I Cant Adjust The Temp In Ac Mode Or Panel (vent) Mode. Help
