AC Blows Warm and Cycles On and Off
Old May 9, 2007 | 08:55 PM
theColonel's Avatar
I recently bought a 97 F150 with the 4.2L V6. The AC worked off and on for the first couple days, but now it only blow warm air. I can also hear the compressor cycling on and off every couple of seconds when the AC is on. The compressor is new along with some of the lines. I believe the freon was replaced not too long ago. Does anyone have a suggestion as to what might be wrong with my AC?
Old May 9, 2007 | 09:08 PM
uknigel2's Avatar
sounds like you need to check the blend door operation. Most give up around 10 years old. Check this section of the message area for details.
Old May 10, 2007 | 08:06 AM
projectSHO89's Avatar
Uh, no. If the compressor had been reported as cycling normally, then yes (probably).
He has a short-cycling compressor. That means an undercharge and probably a leak. An undercharged system cannot provide any cooling for the HVAC system.
Steve
Old May 10, 2007 | 10:13 AM
Les22's Avatar
I have the same problem with my 97. It was recharged by the dealer about two/three years ago (It cost me over $129) because it was doing the same as theColonel's.
Now its doing it again
Can theColonel and I hit up an Autozone and buy a $49 charging kit?
Old May 10, 2007 | 03:14 PM
MemphisE34a's Avatar
Don't feel too bad. I have 2005 that does the exact same thing and the dealer says it is within "normal" specs.
Old May 10, 2007 | 04:50 PM
keith97xlt's Avatar
49$?? ive seen them at autozone for 20$. just recharged my friends jeep cherokee last week took 10 mins.
Old May 10, 2007 | 07:01 PM
theColonel's Avatar
Thanks for all of the advice. It sound like the compressor is short cycling. I will try the $20 option for refilling the freon first and go from there.
Old May 10, 2007 | 08:23 PM
Wolverine1fan's Avatar
I had the dealership tell me the same thing with the same exact condition on my 2004, the second time I took it back they finally determined the compressor was bad. Go figure! New compressor, nice cold air!
Old May 17, 2007 | 05:29 PM
norrisboat's Avatar
What do u mean by the term "short cycling"?
Old May 17, 2007 | 09:01 PM
skooba's Avatar
It probably is cycling off the low pressure switch which means you need to add freon
Old May 20, 2007 | 10:11 AM
theColonel's Avatar
AC is Working Agian
Thanks for all of your help guys. Apparenetly the clutch on the compressor was loose and it actually fell off. I bought a new clutch and replaced it and the AC works great now!
