Heater control
Old Apr 22, 2005 | 02:09 AM
Fordscott's Avatar
Heater control
My heater core son my 97 F150 sprang a leak a few weeks ago so I had to remove the dash to replace it. I thought it worked fine but now I notice that sometime hot air will only come out and somtimes only cold air will come out, it doesn't matter which way I turn the ****. Did I break the **** or temperature control when I was replacing the core? Did I somehow put the door in the core housing back wrong? Help me, this is driving me crazy!!!
Old Apr 22, 2005 | 08:50 PM
Yankee7985's Avatar
Remove the **** and look at the part that goes over the input shaft of the hot/cold rheostat. Chances are you will find that it is probably cracked. Less than $10.00 to replace.
Old Apr 22, 2005 | 09:57 PM
Fordscott's Avatar
Unhappy
Thanks, but now I have another question. This morning I started the truck and, didn't turn any *****, and smoke came out of some wires are located under the heater core box, but more towards the middle. Is that the actuator I keep hearing about for the blend door I keep hearing about? Did it just fry? If so, why?
Old Apr 23, 2005 | 04:54 PM
svt_sc_f150's Avatar
when the heater core leaks, the coolant goes right into the actuator. When I do heater cores, I replace the core, the blend door, because they crack where the actuator goes in and you have to pull it all apart again to replace it. It only costs about $35, and I replace the actuator, because the coolant goes into it. It may not have any problems at the time, but in a little while as the coolant makes it's way further into it and reaches the motor it shorts it out. So there should always be 3 parts replaced when doing a heater core. The core, the blend door, and the actuator. Not to mention the coolant flush and checking the cooling system for electrolisys.
Old Apr 24, 2005 | 12:52 PM
Fordscott's Avatar
Thanks. I pulled the acuator yesterday, which was alot easier to get to than the core, and sure enough, it was fried. I opened it up and coolant residue all over. I wish I new about this site before all this started. Thanks for your help. BTW, I did check to see if the blend door was free and it is. Hopefully the door will list a while. I just don't have the time or energy to pull the dash again.
Old Aug 30, 2009 | 06:34 PM
dayalalito01's Avatar
Mr Fordscott,
im new and having issues with the accuator, im getting AC but when i give it gas the AC turns to HEAT, AC has been checked an is full, everything leads to the Accuator, but
i cant seem to find it under the dash .
can you pls helpme in advising where the heck it is located .
Tnxs
Dayalaito@gmail.com
Old Oct 18, 2011 | 06:25 PM
dfbradley's Avatar
94 F150 replace thermostat, heater Core, didn't have no heat, old core 3 times heavier than new, however still not heat. Cable control doesn't want to turn all the way to the right at first but it will eventually. Still no neat I believe something is wrong with the temp control door. How do I replace this?
Old Oct 18, 2011 | 06:28 PM
dfbradley's Avatar
Where can i get F150 parts without going to a new car dealer if it is a dealer part only?
