97 f150 no heat - whats the problem?
I have a 97 F150 with 150,000 miles. I had antifreeze smell in the cab back in the summer so I used stop leak. The problem went away and never had any problem with the AC. My heat has not worked since I first tried to use it this past fall. Neither heater hose is getting hot. The top radiator hose doesn't always contain any solution (I can compress it with my hand), but the overflow tank is full. I took the heater hoses loose and forced water thru the heater core in both directions (no problems). I then forced water thru the unconnected hoses back the opposite direction and it flowed fine (both directions). I changed the thermostat (even tested it without a thermostat), I changed the pressure cap and no difference. The engine temperature comes up to normal from overnight quicker than I'm used to ( about 1 mile in 35 degree weather) but seems normal and the engine has never overheated. I don't believe my problem is under the dash since the heater core is not stopped up and the blend door changes air speed switching from cold to hot, anyway the heater hoses never get hot going into the heater core. Does anyone have any suggestions? I appreciate any suggestions.
My next step is to take it to Ford and take out a loan.
Thanks,
Dan Benson
Thanks,
Dan Benson
Yes Sir, the thermostat is installed correctly. Do you know where the heater core is fed from? There isn't a lot of room under the hood but from what I gather there isn't a feed from the water pump as in most older engines. I thinking this is where my problem lies. I can trace the heater hose connecting to a hard pipe going back behind the engine but I can't determine where it goes. The other side of the heater core connects to the intake at the back of the engine.
Thanks,
Dan
Thanks,
Dan
