AVH-3200BT or AVH-P3100DVD
Old 04-06-2010, 08:10 AM
ChrisAU's Avatar
Originally Posted by AZMike74
I have the 3100 and a backup camera so I can say for sure they do support rear view cameras.
^x2
Old 04-06-2010, 11:13 AM
x2mosg's Avatar
AZMike,
Thanks, I'm looking at the 4200DVD and those or the Ref speakers, can't decide. Maybe Kappa front, Refer in the back. Eventually powered compact sub under seat.
Thanks,
David
Old 04-06-2010, 11:32 AM
thejake1989's Avatar
Originally Posted by Dinggus
I can't decide what to get, the AVH-P3200BT or AVH-P3100DVD. I want bluetooth, and navigation can come later. Would I still have to modify my dash to get the HU to fit properly? I can get the 3200BT for $380 and the P3100DVD for $308.
AVH-P3200BT
AVH-P3100DVD
Not looking to spend much, but, something I can still enjoy, just in case I go on a trip my wife or friends can watch something and I can still be safe on the road with bluetooth hands free.
glad you finally started to listen to me and go with pioneer haha. and get the new model just because they come out with so many new features every year youd regret it later.
Old 04-06-2010, 11:57 AM
Dinggus's Avatar
Is the x710 older than those?
Old 04-06-2010, 12:51 PM
Sundevil2188's Avatar
the 710 is the same model year as the 3100. havent seen the replacement for the 710 yet, but I know the 920 is out there (replacement for my HU)
Old 04-06-2010, 01:22 PM
Dinggus's Avatar
Okay, so the x710 is still not quite outdated? And I figured might as well get navigation built in as well for the same price as the P3100BT
Old 04-06-2010, 07:48 PM
no not by any means is it outdated. There are still guys on here buying D3's for more then what you'd be paying for that 710.
Old 04-06-2010, 09:17 PM
Dinggus's Avatar
Well the x710 fell threw, so I can grab the P3200BT for $315 shipped.
Old 04-07-2010, 12:43 AM
You can add nav to the 3200 too...
Old 04-07-2010, 04:02 AM
Dinggus's Avatar
Yeah I know, I figured might as well spend the same amount and have it built in. I also have an issue, my aftermarket deck, we had to clip the harness off and attach the wires by using the electrical tubes and wrapped them in electrical tape. Would that be an issue with this new deck that I'm about to buy?
Old 04-07-2010, 11:43 PM
You cut the harness on the truck side? Thats a big no no but its easy to remedy. If it were me I would wire a reverse harness back into the truck and do it the correct way vs. hardwire.
Old 04-07-2010, 11:50 PM
Dinggus's Avatar
Yes, we did, ha. How would I do that? Just buy a harness, cut it, and re-wire it?
Old 04-08-2010, 11:38 AM
Use the 71-1771 to match up to the truck side stock wiring. This gives you the same plug you cut out. Then use the 70-1771 to wire to your radio.
Old 04-08-2010, 08:26 PM
Dinggus's Avatar
Definitely don't know what you mean.
Old 04-09-2010, 07:36 AM
ChrisAU's Avatar
71-1771 will wire up to the wires you cut, giving you a stock plug, just like it had from the factory.
The other one, 70-1771, wires to the wiring harness that came with your head unit and will plug straight into the 71-1771.
I believe he is using Metra part numbers, which you can find at your local Best Buy.
Quick Reply: AVH-3200BT or AVH-P3100DVD
