Gettin Anxious. D3 awaiting install
And SHES IN!!!
I am actually really happy. I had this unit in my old truck and finally got around to putting it in the fx4. With the factory sub I get that pop when it turns on but I ordered the piece from smintech to get rid of that. (not too good at soldering)
Everything works and the unit gives alot more control over the factory sub. For an 8 it actually hits pretty good now. I may just keep it as is for a while instead of upgrading all the speakers, sub, amps etc...
If I can't find a 500/5 I'll to the 300/4 and the 500/1 (which is what I had in my old car and sold....that I should have kept!)
Its very easy. Just go to crutchfied and enter your truck year make model etc... It will tell you which wiring harness and mounting bracket you need. If you have an 07 + you will need an antena adapter. If you have the factory sub, I recommend the smintech 7805 5v regulator to get rid of the pop when you turn the stereo on. You can buy the stuff from radioshack but I suck at soldering so I figured the 12 bucks is worth it.
if you buy the one from sminntech then technically you dont have to solder anything. You can crimp the whole wiring harness together if you want, which is what I did.
Also before you do everything do the bypass on the navigation. You have to move the mute wire to an empty slot on the same harness. Avic411 has pictures. Then you ground the parking brake wire and the mute wire. Voilla!!! Now you can watch movies while driving, errr ummmmm, now you can change the destination address on the fly without having to pull over.
if you need help let me know.
Scosche FD23B 2004-Up Select Ford Harness <- Wiring harness
Scosche FD1426B Double ISO DIN Kit for 2004-Up Ford <- Dash Kit
Got them from Amazon.com you can probably get them cheaper elsewhere
You can also confirm the part numbers at http://www.scosche.com/
Wiring Harness
Mounting Kit
On the mounting kit you cut off the rear u shaped pieces.
Factory Sub Pop Fix
Mounting Kit
Factory Sub Pop Fix
I think its the same. You might need an antenna adapter. The harness I used had a few wires that i did not use (roughly 5 or so), possibly for the higher end stock headunits. I had the 6 disc CD changer, nothing fancy.
This is what i found from Scosche, hope it helps
Current Vehicle Selection: 2007 FORD F SERIES PICKUP
Application Kits
Specific Kit: FD1424B
ISODINMount:
MultiKit:
DoubleISODINMount: FD1426B
SoundKase:
Retail15DIN:
RetailDoubleISODINMount: FD1432
RetailISODIN:
Wiring Harness Applications
FAI:
Wiring Harness: FD23B
Factory Harness: FD23RB
FAB:
Retail FAI:
Antenna Applications
Antenna Adapter: CRAB
Factory Radio Antenna Adapter: CRARB
Retail Antenna Adapter:
Retail FM/Satellite Modified Adapter:
Satellite Radio/CD Changer Kit:
Speaker Applications
Dash:
Kick Panel:
Front Door: 6 x 8
Back Door: 6 x 8
Rear Side Panel: 6 x 8
Rear Deck:
Tailgate:
Application Kits
ISODINMount:
MultiKit:
SoundKase:
Retail15DIN:
RetailISODIN:
FAI:
FAB:
Retail FAI:
Dash:
Kick Panel:
Front Door: 6 x 8
Back Door: 6 x 8
Rear Deck:
Tailgate:
