DNX8120 and Factory Sub?
Old May 25, 2008 | 07:59 PM
o4screw's Avatar
Guys,
What's going to happen with my Factory Sub once the DNX goes in? Will the connections power the subwoofer? Or do I have to get rid of the sub along with the oem headunit?
Thanks!
Old May 26, 2008 | 02:18 AM
KCAutosound's Avatar
Originally Posted by o4screw
Guys,
Thanks!
With use of the Metra 70-5521 harness you'll be happy to find out that you will have full control over your factory sub's volume and frequency. The way the original factory setup worked is that your subwoofer's volume went up with the entire volume of the system. Now you'll even be able to turn the sub off if you like.
Old May 26, 2008 | 12:50 PM
o4screw's Avatar
KC:
Good, politically correct answer! I really don't want to keep the oem sub.. in the near future I will replace it out for something with a bit more... power.
In the meantime, I need some bass augmenting the speakers.. so I opted to keep the oem setup back there for now.
Thanks for the part number. Can I get that part though you?
Old May 26, 2008 | 12:52 PM
BLACKOUT FX4's Avatar
i assume this will work for the saleen powered sub too?
Old May 26, 2008 | 01:39 PM
Correct I do sell the harness. Also it is the same harness for all audiophile systems. When you say the Saleen sub what do you mean? Do you meen the premium sound in a saleen mustang?
Old May 27, 2008 | 07:07 AM
cscott1's Avatar
Do you happen to sell a sub harness from the HU to the sub for the stock audiophile?
Old May 27, 2008 | 07:21 AM
the 08 saleen f150 has a rockford/saleen powered sub under the rear seat. its also available on ebay. search saleen f150
Old May 27, 2008 | 08:56 AM
Sorry I don't have access to those.
Just looked on ebay. I don't think I've ever seen any of the Saleen trucks hit Kansas City before. Lots of Roush and other versions. The 70-5521 harness will be the same since the radio is the same. This is where all the harnesses plug at.
Old May 27, 2008 | 11:58 AM
cscott1's Avatar
Thanks KC, I am a little bit confused now because I now have an 08 F150 which didnt come with the audiophile stereo and have taken the stereo and speakers out of my 05 which had the audiophile system. Now I plugged the connectors into the HU and had to pull the Sub plug from the little storage blankoff on the harness, but what really is bothering me is that I know where the connector should be to plug into the Sub/amp unit but I for the life of me cannot find one. I find it kind of strainge that Ford would put the connector there for the head unit but wouldnt terminate it with another plug for the sub/amp unit. Does anyone know anything about this on the 08's and if they may have stashed the sub plug somewhere else? I know my 05 has two shielded wires running down the driver side under the plastic step and they go right to the connector for the sub, but on the 08 the shielded wires run down the same way but when it gets past the driver seat it runs behid both front seats to the other side and back up front under the passenger front plastic step and after it goes up inside the dash is where I lose it. I have been under the carpet in the whole back seat area on both sides of the truck and cannot find it. Any ideas from you knowledgable folks???
Sorry, I am not trying to hijack thread, but I have looked and searched all over here with no help and this seems to be the closest current threads conccerning sub and you all sound pretty knowledgable... thanks
Old May 27, 2008 | 12:30 PM
th3godf4th3r's Avatar
so n the Metra 70-5521, is all i need to buy is that? then i dont need to go buy another harness correct? because that does the speakers,power and sub?
Old May 28, 2008 | 06:51 AM
cscott1's Avatar
Smile
Anyone with any help on this????
