Auxillary In Location?
Old Nov 28, 2007 | 01:43 AM
prater's Avatar
I have an 06 F150 STX with the stock single disc radio, there is an AUX button on the front but no input jack. Where is the input jack, if I say I wanted to plug in a CD changer or mp3 player, where would I find this jack? Okay pretty sure its on the back, also on PIE found a can-bus auxiliary input converter. So here is my plan, install a can-bus AUX input converter, then use an RCA to 1/8 inch adapter to to go between my Zune MP3 player and the converter and I should be able to listen to my Zune on my car stereo right? Has anyone done this or is there any reason this would not work?
Old Nov 29, 2007 | 05:32 PM
Buzzz's Avatar
Yes, it is for a cd changer. There are adapters that plug into the changer port and let you use that as a aux input for ipod, zune, etc.
Old Nov 29, 2007 | 05:33 PM
Buzzz's Avatar
http://cgi.ebay.com/ebaymotors/2004-...spagenameZWDVW
Old Nov 29, 2007 | 07:01 PM
Neggy's Avatar
go buy the 07 dash tray and the cable that connects the AUX jack in the 07 tray to the radio.
read this thread for part numbers.
https://www.f150online.com/forums/sh...=268874&page=3
"....if you order a trAy from the Ford F-150 it comes with the input jack and the part is only List $40.17 FCC $29.91. Part # 7L3Z-15042A82-AA. You would also need part # 3U2Z-14C411-FAA List $20.70 FCC $15.41 ; to plug into that terminal."
