Audophile/6 disc ?
Old Jul 16, 2005 | 06:48 PM
Gordon M.'s Avatar
Audophile/6 disc ?
My new 05 F150 Supercrew is according to the window sticker has 6 disc changer with MP3 and audiophile. The truck does have the 6 disc/MP3 however it does not have the feature where you can adjust for seating positions as stated in the owners manual I do have the sub whoofer under the left rear seat are there 2 diffrent 6 disc/Mp3 radios?
Old Jul 16, 2005 | 07:10 PM
lrhogfan's Avatar
Sentences that start with capital letters and end with periods are a great help for people trying to figure out what you are saying.
If you have the audiophile option, you should be able to press the menu button and change the seating position from Driver to Rear and maybe to something else. I am not sure if there are 2 different 6 disc/MP3 radios. Check the manual against your stereo and you should be able to decipher what you have.
Old Jul 16, 2005 | 09:15 PM
Gordon M.'s Avatar
I removed the radio to hook up my XM Commander there were only 2 plugs going to the oe radio there was a 3rd plug in the wiring harness but no where to connect it at the radio? I am starting to wonder if my audiopjile sub is even able to work
Old Jul 16, 2005 | 10:28 PM
dragonman's Avatar
Nope-- the signal pins are not driven although there is indeed live power
at the sub connector. I was hoping I could just slap in a sub on my non-audiophile HU...it's not the case :-(
Old Jul 17, 2005 | 07:44 AM
Gordon M.'s Avatar
So I guess my truck left the factory with the wrong radio in it the sub whoofer does not work as it is not connected at the radio nor is there a place to connect it
Old Jul 17, 2005 | 10:53 AM
HotLap's Avatar
Gordon - take it back to the dealer and have them investigate. There are different Audiophile set ups....for instance in my '05 Lariat 4x4 SCREW, I have the 6 CD (non MP3) with Audiophile and my brother's exact same truck, (he bought his 1 week after I got mine), has the Audiophile system with the 6 CD AND MP3......his started as the "Preimum Sound Package" then the Audiophile was added by the factory - whereas mine started as (according to my window sticker) a non CD head unit and it was upgraded to a 6cd player with Audiophile option.....I know this because the window sticker reflects a seperate charge for the 6CD upgrade and the Audiophile options. Additionally, my HU does not have any labeling, whereas, my brother's has the "6CD/MP3" labeling right on the face. We compared both sound systems and belive it or not we agree that mine appears to have more power/sound better than his???
Old Jul 17, 2005 | 02:19 PM
Gordon M.'s Avatar
I will be taking it back to the dealer Truck is new and I believe has the wrong head unit sub under left rear seat does not work no sound from sub,also many of the things that should come up when the menu button is pressed are not there (seat position,RDS) Thanks for the comments I will post with results of what the dealer does
Old Jul 19, 2005 | 01:33 PM
FordNoobie's Avatar
If your headunit only has two plugs in the rear, then you definitely do NOT have the audiophile headunit.
Old Jul 19, 2005 | 07:58 PM
Gordon M.'s Avatar
Called the guy at the dealer that I bought my truck from (internet sales mgr.)he said no problem he is ordering a new head unit I will post again after it is installed.
