Rotor question
Old Nov 27, 2002 | 12:01 AM
N2TRUX's Avatar
Here's what I used on my Z-28 when we showed it. It worked great, and can be brushed on, or thinned down and sprayed on...
Stainless Steel Paint
Old Nov 28, 2002 | 01:38 AM
dermaestro's Avatar
Rethinking...
Now I'm rethinking the sanding/rusoleum route. I'm gonna have to think about this some. I want this to last, so I want to make sure I do it right the first time.
Thanks for the input!
Old Dec 2, 2002 | 02:24 AM
Ayrton's Avatar
I painted my rotors with some high temp aluminum paint, and this has held up fine after over 500 miles. Make sure whatever paint you use is high temperature, at least 1500 degrees. http://www.fordtruckworld.com/mygall...86&album=12369
Or you can replace the rotors with upgraded rotors from Ruslow. They are available powder coated so that the pads wear off the paint and the rest of the rotor is painted.
Rob G had these on the Hooter’s mobile.
