Better (easier) foglight mod!
Old Sep 23, 2002 | 05:44 AM
  #31
Treadwheeler's Avatar
Stock Switch Mod
BlownHarley or anyone else that has modified the in-dash light switch. As all the posts in this string have indicated, both mods achieve the desired results, though I'm with the group that would prefer to control everything from one switch - Could you post the mod you had to make to the stock in-dash light switch.
I pulled it yesterday and cut the black plasit "pin" inside the switch housing that stopped the switch from pulling all the way out in any position other than the most right where you can turn the fogs on with the lights on. It was the "pin" that was guided by the plastic bezzel like a cam. The light switch now pulls all the way out (like you were turning the fogs on in stock switch configuration) in any position but the fogs still only come on in the original position. There was mention of a white tab that was either cut or melted - I did not see any thing else to modify? Do you have to go deeper into the switch?
Treadwheeler
Old Sep 23, 2002 | 03:23 PM
  #32
Harley#356's Avatar
Tread, i believe you also have to do some splicing with the wires to get the total effect. Here's the how to from this site:
https://www.f150online.com/tech/lightningfog1.html
Old Sep 23, 2002 | 07:59 PM
  #33
BlownHarleyFord's Avatar
Tread,
No monkeying with the wires is necessary unless you have the daytime running lamps. The link 356 gave explains it better than I ever could. I basically pulled the switch and figured it out. I however took the switch completely apart to perform the procedure. I used a soildering iron to basically "rivet" it back together at the original fused locations. It's just my opinion that extra switches are hokey, and that's why I decided to do it this way over a year ago. In my opinion, the function is much more "stock like."
Old Sep 23, 2002 | 08:27 PM
  #34
MHTYFman's Avatar
Unhappy hey guys???
hey
i did your little mod there harley356, but i have one problem now, i think i burnt the fog light switch on the stock setting beacuse i was driving one night and hit the HI's on and the fogs where on with my switch and not they wont work when i try to turn them on stock. anyone else have this happen???????????
keith
Old Sep 23, 2002 | 09:52 PM
  #35
Harley#356's Avatar
i haven't had any problems yet luckily. but it wouldn't suprise me if i did with my kind of luck
any chance a wire came loose where you spliced it? or its a bad or faulty extra switch???
hope it all goes well and you figure out the problem. keep us posted.
Old Sep 25, 2002 | 05:49 AM
  #36
Fog Lamp Mod - Switch
Thanks for the info -
The link was accurate. With the mod I made to the black plastic pin the fogs were coming on in the autolamp position which they don't do in the stock switch configuration. Looks like the only thing left I need to do is the splice together the #2 & #12 wire to get them to come on with only the parking lamps as well.
As far as the mod to the plastic pin versus filing down on the plastic colar to provide additional slots allowing the switch to be pulled out in additional positions other than stock - I'm OK with the results and the feel of the switch. It is completley functionable and the mod is transparrent - Espcialy considering the fact that no additional switch is needed.
Old Oct 14, 2002 | 04:06 PM
  #37
mschon's Avatar
Lightbulb
Well I finally got around to doing the same mod to my 2002 as I had done to my 2000. This time I installed as switch though, so I can turn the Fogs off and still use the Auto feature. I put the switch in the kick panel.
Picture 1
Picture 2
Old Dec 23, 2002 | 10:00 PM
  #38
moto93's Avatar
Originally posted by tbutler1
Is there a constant power I can pull from? I would like to be able to have the fog lights on seperately w/o running lights etc. Thanks
Yea, you can do that! I just did it to my '03 Supercrew and can now turn the fogs on/off any time I want. What I did was grind the switch (with a dremel) so I can pull it out in the off position and spliced #2 (white & black) to #8 (blue & orange).
Hope this helps,
moto
Old Dec 23, 2002 | 11:36 PM
  #39
Harley#356's Avatar
geez, you used your 1st post to dig a dead thread back to life?
welome to the site!
Old Dec 24, 2002 | 04:56 PM
  #40
moto93's Avatar
welome to the site!
Oh well, I had to start somewhere!
SMC
Old Dec 25, 2002 | 09:30 PM
  #41
JCZ's Avatar
JCZ
Josh I need a little more education here. The panel that surrounds the headlight switch has a notch in it at the bottom center. I put a screwdriver in it, but it doesn't seem to want to pop loose. Am I missing something? Am I just not prying hard enough or am I about to break it?
Also, the dash dimmer switch is in the same panel. Does it come out with the panel?
Old Dec 25, 2002 | 10:03 PM
  #42
Harley#356's Avatar
yup that all comes out as one piece. not sure why it isn't working, but maybe you need a longer screwdriver? make sure its really think, like a jeweler's screwdriver, and once the bottom releases just a little, do the same for the clip on the left center, and then the top right. it can be a little tricky at 1st, but once you figure it out its pretty easy. just be careful. 70 bucks for a new one
hope this helps some
