HELP....need bass
Old Jun 12, 2002 | 07:50 PM
drop-top's Avatar
HELP....need bass
Secondary to the unique back seat setup of the 02s, I am unable to use my sub box with two 10 inchers in the the new truck. So, I replaced all 4 speakers with a pioneer plate system with my amp and its sounds good and loud but no real bass and I miss the sound I had in my F250. What are you guys doing....there is not much room back there. Even one 8 inch would surely do the trick. Any suggestions.
Old Jun 12, 2002 | 08:42 PM
Towboatz's Avatar
The blackwoods has a 8 inch sub stock a little pricey $290.-220. ford can get it also, i had a 10 inch in the rear console on bottom installed .To replace the console was cheaper than the other way.
Old Jun 12, 2002 | 10:49 PM
drop-top's Avatar
Tell me more about your install. Did you remove the console for good? Have any pics? How is the sound?
Old Jun 13, 2002 | 12:06 AM
2000F150HD's Avatar
i think subbox.net makes a box thaty fits in the crew.... but now that i think i dont think it will fit with the buckets.... i dont think it is that hard to have a sub put into the console... but i would have it done.... unless you are good with fiberglass and epoxy.
-steve
Old Jun 13, 2002 | 01:11 AM
Harley2001NJ's Avatar
Hey All,
I put a 10" Alpine SWR-1041D in an enclosure behind the front console. It has a Dual Voice Coil. I get no buzz from the front console.I have an MTX Thunder 6500D Amp. It hits hard and has DEEEEP Base. The MTX has a cool feature on the amp that you have a seperate control for the output of the bass amp. Its a little dial i mounted up front. Here are some pics... Hope it helps...
..Sub
..Sub Level
More Here..https://www.f150online.com/galleries/albumview.cfm?num=1765
Old Jun 13, 2002 | 01:31 AM
dave-hd's Avatar
Drop Top---On another site we have made sub boxes that fit under each bucket. Yes I known it looks small but Rockford Foose makes a 6.5" sub that will fit and while I have not finished mind as yet, the guys who have completed them are real happy with them. Go to Rockford web page to get more info on the sub. Other than a few mesurements i had I used cardboard to design my boxes. E-mail for any other info if you need it.
dave hd
Old Jun 13, 2002 | 01:48 AM
blowfish's Avatar
12's Can Be Done
If you want to put a sub behind the rear seats, where it belongs. I am having a complete audio video system installed in my 02 HD. You sound like a man who appreciates a good amount of bass, I do as well. I had the rear seats moved forward 2 inches to make room for a proper sub enclosure. This enclosure can be made from wood or fiberglass. I have some photos of the install in my gallery. I am going there tomorrow to check the progress and take more photos. I hope you take the time and effort to do a proper install in your truck. I have seen a lot of crap installs on this site.
https://www.f150online.com/galleries....cfm?gnum=1350
Old Jun 13, 2002 | 07:14 AM
drop-top's Avatar
Thanks guys. Blowfish, did you have to cut any of the plastic behind the seat? Harley2001nj, did you build the box or was it pre-fabed?
Old Jun 13, 2002 | 09:52 AM
blowfish's Avatar
No Sir, I don’t believe in doing any permanent hacking or cutting to the vehicle.
Old Jun 13, 2002 | 04:47 PM
01BlkLariat's Avatar
blowfish
I can't wait to see the finished product of your sound system....Seems like its going to be really nice.......
Old Jun 13, 2002 | 09:18 PM
Towboatz's Avatar
Thumbs up subs in o2 harley
The install went awsome the sub went into the same place the square hole is in that the blackwood will go,they built a box inside the rear compartment and put the 2 -10 inch jbl subs cant even tell they are there until you fire it up!!! boston acoustics in front and rear passive crossover in front alpine mr500 5 channel amp under the front pass. side. front and rear strobes police quality controlable,, next the engine... later
Old Jun 14, 2002 | 09:28 PM
slingshot's Avatar
Towboatz--Pics! ...Please?
Old Jun 15, 2002 | 09:19 PM
abullerm's Avatar
Re: 12's Can Be Done
Those are some excellent pictures of your progress. I was just pondering the installation of my old subs and amps from my old T-bird this afternoon (they don't do much good sitting in the garage). I was going to make a subbox.net type enclosure for under the rear seat but I like to fold the seats up to carry large items as to not damage the leather and haven't made a box because of it. I like your idea of moving the seat forward and using the low profile subs. Could you post a link for those subs and where you purchased them?
