"Service engine soon light" is on!!
"Service engine soon" light is on!!! 35 miles on the truck and this happens, I hope it's nothing major?!! I've checked all the small things (loose gas cap, etc.) but all looks good and it runs/drives fine. Dealer isn't open on Saturdays so first thing Monday morning it'll be there!! Truck manual said it also could be from "bad" fuel, could the dealer have put regular instead of premium fuel in it?
Not a very happy first time HD owner,
Sean
Sean
Had that happen to mine after 500 miles. the light came on while passing a transport on the highway. After they downloaded the computer codes they say it showed overboost. The service engine soon light blinks when you pass a certain boost, and will stays on if you pass another threshold. They cleared the fault and it did not occur again, to date.
Thanks for the Harley#356. It was the PCV, a guy on the L board was having lean codes too and one post stated to check the PCV.... so that's what I did just for sh** & giggles and BEHOLD the PCV wasn't pushed into the valve cover. All is well now and after some drivin' it still looks good..... no engine light!!!
Sean
Sean
The factory only puts in a couple of gallons in the tank. Ford expects the dealer to fill up the vehicle with premium, regular or diesel before delivering the vehicle to the customers. When you received your survey from Ford there should have been a question for you to answer about the dealer giving you a full tank of gas.....
