Anyone added batteries to HD?
not exactly on the topic, but does anybody know where the cheapest place is to get an optima battery? my stock battery already died on me once and needed a jump from my 85. when it started up again, it was barely in the charge range, so it barely died.
Plus with me adding more lighting and stuff, i'd feel better with a better battery.
thanks
thanks
Originally posted by crockett59
Mark,
Just wondering why? Why do you want to add a battery? Just curious.
Mark,
-Mark
thanks crockett. which one would should i get though? yellow top or red top? i know there's a difference between the 2, but i'm not totally sure on what would be best for me. i looked at their site, but that didn't help any
i don't put many miles on my truck, so they are mostly short trips, and 1/2 of those at night with the lights on and radio always on (i think thats why it died the 1st time, not enough longer drives to give the battery a good full charge). And i've also got that neon, even though i heard it doesn't use much power, and i plan on doing a system eventually. I'd like to get the red though mainly cuz it would match my engine bay but if the yellow would be better for me, then thats what i'd get.
Okay,
The yellow is 870 cranking amps 550 cold cranking amps
The RED is 980 cranking amps and 800 cold cranking amps
That's why I replaced the yellow with the red. More power. The lights still dim with the subwoofer but, not as bad as the yellow or the stocker.(yuk)
I would go with RED. Oh wait I did
thanks! i thought the yellow was the better one, not sure why, but i'm glad its the red cuz it'll match everything then
Thanks Mark, i ordered my neon lights from them and everything went great. quick shipping and no problems at all. i was worried about a tube being broken or something, but it was all good
i did notice they had optima's on their site, but i thought they were more expensive than that. i'll have to check it out again
thanks guys
Josh,
thezeb.com has the red top Optima for $134.99. I have ordered from thezeb many times and would recommend them.
-Mark
BTW - generally you want Red Top as your primary.. Yellow for addons.
-Mark
thanks guys
