Group Buy: HID projector retrofit kits...
(Approved by Rockpick)
--------------------------- THE GROUP BUY IS ON! AUGUST 1 - 15, 2011 25% discount if we get 25 kits ordered. Discount code is "F15025" (Case sensitive) Group buy general info:
Ordering:
Questions:
----------older information below--------------- GROUP BUY: HID Projector Retrofit Kits from The Retrofit Source (TRS) TRS seems to have a great reputation for sourcing the components for full projector retrofits. While talking to Matt about my own needs, I asked if he would be interested in offering us a Group Buy Discount. He offered us a great deal! This is intended as a do-it-yourself group buy and kit, and I can see setting up a specific thread to help participants with the install, but if you wanted to buy the kit and have a "pro" retrofitter do the work, there are plenty of them out there. 25% discount (with minimum 25 participants) on any Stage III complete retrofit kit. How it will work: We determine interest level and get commitments from members. Once we have enough to start the group buy, a discount code will be generated and everybody will order their kits directly from RFS. Example Kit:We can do the group buy with less than 25 members, but the discount will be less. There is no limit on maximum number of participants, but there will be a window for the group buy that will close at some point. This is the kit I'm looking at for myself (2011 FX4) as an example. After talking at length with Matt, it seems like this projector/shroud combo will work very well with the large 2009-2011 F150 headlights, but might also be a good solution for other years. You might need to select a smaller reflector shroud for previous generation trucks. The group buy is also good for other projector kits, including the Bi-Xenon FX-R and the Morimoto D2S kits. You can also opt for different shrouds, bulbs, or ballasts.BI-XENON MORIMOTO MINI H1 STAGE III KIT.
After 25% discount: $221.35. Shipping should be less than $10 in the Cont. US. These MoriMoto Mini H1 (MH1) projector kits are fourth generation, and the light patterning and cutoff is arguably the best out there. Up to now, many have felt that the FX-R retrofits had the best pattern, but now most of the "knowledgeable guys" on the HID forums think that these MH1's have as good or better light patterning and cutoff. Digital ballasts, top quality bulbs, plug-and-play wiring harnesses. Furthermore, with these new MH1 kits, there should be no plastic cutting or hassles with alignment. They come with a H14 alignment adapter that should make the job very easy, with the only task that is difficult at all being opening the butyl seal on the headlights by heating in an oven for a few minutes or with a heat gun. "The Morimoto Mini bi-xenon complete kit includes the ultra-compact Mini bi-xenon projectors, the proper HID bulbs, and a set of 35w digital Morimoto ballasts to power them. It doesn't get any more "plug n play" than this." The Kit: http://www.theretrofitsource.com/ima...stage3-06l.jpg The Apollo shrouds: http://www.theretrofitsource.com/ima...hroud%204l.jpg The wiring harness: http://www.theretrofitsource.com/ima...ZoomedOutl.jpg Beam pattern photo from Moromini H1's: http://i59.photobucket.com/albums/g2.../DSC_3677h.jpg Here is a link to a step-by-step install of the MH1 in a different vehicle. Note that you will not have to do the alignment steps (#6 and #10) with the H14 adapter rings. I have no personal affiliation with theretrofitsource. I'll just be an owner installing the kits myself, just like you. They do seem to have a pretty fantastic reputation though. Interested:
Originally Posted by pfb2
(Post 4638763)
SIGN ME UP!!!
I was gonna buy a set anyway! Hopefully we can get enough to get the 25% off code before august 1st because they're running 10% off any complete kit until then so 35% off would be amazing |
Super PUMPED
Does this GB work for 03s as well?
(Post 4638763)
when is the order date deadline? Interested.....
Originally Posted by migdaddy
(Post 4640935)
does this gb work for 03s as well?
I'm in.
Don't see why it wouldn't be for other trucks as the GB is for the kits, which can be installed anywhere you want.
I'm interested and also want to know when the deadline for turning in the money will be. I also think I would want a different, smoother, shroud.
I'm in on that other site as well, and will post this there too.
If I order a kit for my heads and a kit for my fogs, does that count as 2 ppl towards the 25? |
gb work for 03s as well? deadline for turning in the money I would want a different, smoother, shroud. |
(Post 4641132)
I'm interested in at least one set. I might want two sets though.
