How can you tell an 01 5.4 from a 4.6?
Old Nov 8, 2001 | 02:50 PM
93coupe's Avatar
Do they both have triton badges? Also what is the lariat package, is it simply leather? My father who is in arizona just purchased an '01 black ext cab, not a screw, lariat with the triton v8 badges. I'm trying to find out if it's a 4.6 or 5.4. Thanks for any help guys.
Old Nov 8, 2001 | 02:55 PM
PSDtoV6's Avatar
Open the hood and look at the motor. If you can't tell by that, look for the engine spec sticker. It should be under the hood as well. Ford used to use different grills for each motor. The honeycomb used to be only on the 5.4. Now you can get the honeycomb with the V6 sport package. The standard V6 and 4.6 V8 grills are usually not the honeycomb style.
Old Nov 8, 2001 | 03:09 PM
dsm327's Avatar
well I've got a 99' and its the 4.6 and it has all the badgeing on fenders and has the honeycomb grille. I think most of the 5.4's come with the 5 star rims and the 4.6's come with the slanted brushed aluminum 5 star type rim. But thats just what I think, dont take it to the bank.
Old Nov 8, 2001 | 03:10 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Question
So the truck is in Arizona and you'r not and your dad ain't saying?
Ask for a pic of the rearend. If the differential cover is round it's a 4.6. If it's eggshaped, laying on the side, it's 5.4.
Old Nov 8, 2001 | 03:25 PM
Showya's Avatar
Hey guys, try this one! Ford Motor Company employee here! If you open the hood and look down between the valve covers under the throttle body(this is the assembly that is attatched to the air cleaner air intake). If you have a gray cast looking intake you have a 4.6L V8. I you have a black plastic looking intake setup, then you have a 5.4L V8. Also there is a badge or Triton logo in every Snow Shield, the black cover over the throttle body which reads Triton 4.6L or 5.4L, just a clue that you can only use one or the other here. The mounting brackets are differ on each of the motors.
ShowYa in Kansas City, gotta run and build another Lincoln Blackwood here.
Old Nov 8, 2001 | 03:33 PM
Dewayne Fuller's Avatar
Raise the hood. The top cover of the engine shows the size in very large print.
Grills and wheels have nothing to do with the engine size.
Old Nov 8, 2001 | 03:54 PM
J-150's Avatar
The fuel gauge on the 5.4's move to the left much faster than the 4.6's
Old Nov 8, 2001 | 04:01 PM
Raoul's Avatar
25 Year Member
Look for a wet spot on the driver's seat.
The 5.4 is scary fast.
Old Nov 8, 2001 | 04:07 PM
CanadianSCrew's Avatar
Raoul,
Good one. After what happened in the milage killer thread I didn't think you would bite on this one. By the way that was funny. You must have over a million miles on that truck by now.
I think i will go start a new thread on "I think I have the wrong engine". Maybe its like the rads. The wrong engines are being put in and don't match up with the grilles.
Old Nov 8, 2001 | 04:19 PM
Neal's Avatar
Cool
HI!... All LARIATS come only with the 5.4. Well at least they do here in CANADA. The 5.4 is standard with the LARIAT package.
Old Nov 8, 2001 | 04:38 PM
93coupe's Avatar
Yeah, he's in arizona, and i'm in texas. And i'm sure he doesn't know and i wanted to know with out asking him to do some detective work.
So I guess there is no definitive badging distinguishing the two for 98+ trucks right? The 4.6s got 'triton V8' badges as well as the 5.4s?
Old Nov 8, 2001 | 05:22 PM
Neal's Avatar
Cool
HI!... Yes all F-150's equipped with the v8's get the TRITON badging from "98" and up. Another way to tell if you have a 5.4 or 4.6 engine from the outside of the truck is to look at the rearend. All 5.4 equipped F-150's come with the STERLING 9.75 rearends. All 4.6 equipped F-150's come with the STERLING 8.8 rearend. The 8.8 looks the same as the rearends in the MUSTANG and the 9.75 looks a lot like a DANA 60 rearend except for the DANA 60 is a bit larger in case diameter.
Old Nov 8, 2001 | 05:34 PM
Andthensometoo's Avatar
Trust Neal to know his rear-ends.
Old Nov 9, 2001 | 04:13 AM
Pickup Man's Avatar
I have a Lariat with a 4.6, a honeycomb grill, and no badges except the one that says F-150. And I think my rear-end is way better now than it was when I was in high school. I have lost 85 pounds!
Old Nov 9, 2001 | 09:58 AM
jryager's Avatar
I would suspect that 93coupe was interested in knowing how to tell a 4.6 from a 5.4 when sitting next to an F150 as the first cars on a 4 lane street.... without getting out, running to the back of the truck and looking under the rear of the truck and getting a face full of exhaust, rubber, stones, dust, etc when the light turns green..........
