I "Think" Therefore I'm Dangerous.
Old Nov 30, 2011 | 12:33 AM
OGTerror's Avatar
I planned it that way, thatz why I molded the box the way I did.
Old Nov 30, 2011 | 12:50 AM
OGTerror's Avatar
Tomorrow you'll see the finish product.
Old Nov 30, 2011 | 12:58 AM
rednoved's Avatar
You should put a wire/mesh covering over that hole. It would look a lot better.
Old Nov 30, 2011 | 02:13 AM
OGTerror's Avatar
Relax, take it easy don't worry about it, I'm not done yet.
Old Nov 30, 2011 | 07:25 AM
SSCULLY's Avatar
When you get a moment, might want to check the knot on the rope holding the winch on.
Looks a bit loose, and if you try pulling the truck out of the mud, it might come undone. Surgeons knot would hold it better. .
Old Nov 30, 2011 | 09:27 PM
OGTerror's Avatar
I use surgical knot only when fishing but still the big one did get a way.
Old Nov 30, 2011 | 09:32 PM
OGTerror's Avatar
Today I proceeded to finish off the air vent:
I had to modify the bottom back of the box in order for it to fit behind the wheel well.
This is what the finish product will look like at the end:
Old Dec 1, 2011 | 12:39 AM
che22879's Avatar
Looks good!
Old Dec 1, 2011 | 10:59 AM
azmidget91's Avatar
What's the reason for the metal riveted to the edge of the fender? Also I would have probably put the intake hole somewhere that isn't going to be hit by water...
Old Dec 1, 2011 | 11:47 AM
OGTerror's Avatar
The riveted metal was to create an edge to give me a smooth curb so the fender flows with the bumper.
I added a downward curb and a drain at the end to avoid most of the water from traveling up and touching my air filter. Remember most of my muddying is only minor.
Old Dec 1, 2011 | 11:49 AM
JackandJanet's Avatar
I agree with Midget - the possibility of water intake bothers me a lot. But, I may be worrying over nothing. Very nice work, Leo! You sure aren't afraid to "go where no one has gone before". I envy your creativity.
Edit: Your last post snuck in just before mine. Looks like you have everything covered.
- Jack
Old Dec 1, 2011 | 11:59 AM
azmidget91's Avatar
Ok OK not bad
Old Dec 1, 2011 | 12:14 PM
Turned out good!
Old Dec 1, 2011 | 06:32 PM
Alex_4.2L's Avatar
interesting wonder how it will work out. Curious why you didn't go with something the stuck out the top like jeeps have? Looks?
Old Dec 17, 2011 | 02:53 PM
OGTerror's Avatar
Because I don't want to modify roush's "special" air filter box?
