Just got into a wreck
Old Sep 27, 2011 | 10:08 PM
TXhustla's Avatar
I have a 04 STX(OBS). Both air bags deployed. (Yes Im aware with how much the cost). My question is why are the seat belts locked?? And how can I undo this?? Also how can I get the air bag light to stop flashing?? Thanks
Old Sep 27, 2011 | 10:19 PM
06bluemeaniexl's Avatar
The seat belts are locked, because there is a mechanism that fires when a collision is detected. Only way to fix it, i believe, it to buy a replacement for that mechanism.
Old Sep 27, 2011 | 10:21 PM
Need4racin's Avatar
air bags are going to be used, or just bypassed.
Old Sep 27, 2011 | 10:23 PM
Raptor05121's Avatar
Pics? I hope you can salvage the valence!
oh, and since I am always the late one to these type of threads: "It'll buff right out."
Old Sep 27, 2011 | 10:53 PM
PJB4x4's Avatar
The airbag light wont stop flashing until you replace the airbags and all related parts
Old Sep 27, 2011 | 11:51 PM
TXhustla's Avatar
Last time I tried to do pics they didn't work. I don't think my valace can be saved. However I had someone tell me it and the front bumper could be bent back?
Old Sep 27, 2011 | 11:54 PM
TXhustla's Avatar
Any idea how much it cost and it's exact name? I'm tring to speed up the process for the insurance company.
Old Sep 28, 2011 | 05:10 AM
code58's Avatar
I don't think they'll want it speeded up, matter of fact I'm pretty sure of that. The seat belt tensioners should only go off on the seats that had someone in it with the seat belt fastened. On your truck (OBS) I think the AB's will both go off unless the R one is shut off manually. I believe the 1st inteligent AB's were in the NB '04. Any AB or SBT that goes off MUST be replaced for the AB light to go off. Remember that when the expended components are replaced, the fuse(s) also have to be replaced for the light to go off. I have seen as many as 3 fuses in the AB electrical system and 1, 2, or all 3 MAY be blown. When ALL is back in order, including fuses, the system will shut the light off. On a Ford it doesn't have to be reset because it goes through a self check every time you turn the key on. That's why it takes a couple seconds for the light to go off. DO REMEMBER that the air bag sensors MUST be replaced whenever there is air bag deployment and there is even one in the "brain" in the right kick panel. (box that is "Boss" of the system) There are other things in the system that MAY need replacing. I have done many of them (mostly Fords) and they ARE ALL different. IT IS NOT something that someone who is not trained in it should ever be messing with!!!
Old Sep 28, 2011 | 08:39 AM
pgh_medic's Avatar
Pretensioners fired. The seatbelts are done for and would need replaced if the truck is going to be fixed.
Old Sep 28, 2011 | 10:29 AM
thats what the part I was talking about is called...
Old Sep 29, 2011 | 04:14 PM
TXhustla's Avatar
I didnt have on the seat belt and there was no one in the pass side either. Also is the horn done for as well? After the collision it kept going off. I even remove(fuse box inside truck) the horn fuse. I just unplugged the actual horn...
Old Sep 29, 2011 | 05:16 PM
Take it to a shop and have it fixed correctly.
Old Sep 29, 2011 | 05:38 PM
harleydude78's Avatar
word.
You pay insurance, let them do there jobs and get it fixed the right way. No way I would want a rushed job on something as important as airbags and seatbelts.
Whats the rush? Does your insurance not provide you with a rental or something? I thought that was pretty much standard these days?
Old Sep 29, 2011 | 07:39 PM
TXhustla's Avatar
I have liability. The truck is drivable. The other person is disputing it. My lawyer says this could take a couple of months. And we both have the same insurance compnay. I have already taken photos. And if I get pulled over i heard they would give me a ticket for no seat belt and air bags. Actually I taped the bags back in place pretty good.
Old Sep 29, 2011 | 08:13 PM
get pulled over for missing air bags, no
get pulled over for not wearing a seat belt, yes
