Airbag Light
Front impact severity sensor is what a LFC 42 usually means.
https://www.f150online.com/forums/el...tc-42-fix.html
6L3Z-14B004-AA - Front impact severity sensor
BTW : The recall has nothing to do with the front impact severity sensor, it has to do with the clock spring to driver's side airbag wiring.
Well I pulled it apart & found that one of the pins was stuck in the connector ie had broken off the actual sensor. I tried to glue the pin back into place (I live in hope!!!) but sadly once I had put it all back together the light still gives the same code so I guess its off to the stealership for a new sensor.
