Sea foam who uses it?
I have used it in power equipment and carbureted vehicles before but I would be very hesitant to use it in a fuel injected vehicle because the fuel cools the coils that fire the injectors. So anything that goes in the tank flows over the coated wires in the fuel injectors possibly damaging them.
The makeup of Seafoam, per their website, is the following:
Pale Oil CAS 64742-54-7
Naptha CAS 64742-49-0
Isopropyl Alcohol (yeah, rubbing alcohol) CAS 67-63-0
So who here can tell why it works for all of you?
To remove carbon deposits from a combustion chamber via a "burn" requires combustion temps at 1400F. Pure carbon burns at 1400 Kelvin- that's as hot as some stars in fusion. You cannot "burn" carbon from a combustion chamber. The best remover is water mist. Any attempt to "burn" carbon deposits will result in catastrophic engine failure long before the carbon is "burned" off. The smoke most like to think is carbon deposits is the pale oil burning off. Has anybody considered what that much oil is doing to the cats? Injecting any fluid in massive amounts of volume via the brake hose is a recipe for damage. Your pistons can easily operate at 750F and introducing a quenching mixture into the chamber at those temps will fracture metals. I've personally rebuilt several engines of friends offspring that cratered the engine this way.
I included the CAS numbers for those that care enough to follow the mix but here's some of the direct links for you.
http://environmentalchemistry.com/yo...istillate.html
http://environmentalchemistry.com/yo...roleum%29.html
The alcohol used is of 90-100% pure meaning it has from zero to 10% water in it. If you can find this grade of alcohol at the pharmacy, add about 20% alcohol to ATF and you'll have a far better cleaner at a much cheaper price. At least ATF has some cleaners in it.
Another claim by most additive makers is that it removes varnish. Varnish can ONLY be removed by most of the Keytone family of solvents. Seafoam contains none.
The placebo effect is an amazing thing.
on
x2!
Scientifically speaking - as Labnerd was - you have a sample size of one. It would be unwise to draw too many conclusions from a sample size that small. The 4.6 was a hell of an engine and with regular oil changes, one could probably get that kind of mileage out of one. (There's that sample size thing again.)
NO i could not have driven it further because it rotted out ,,, They use lots of road salt, maybe i should have dumped it on the body and it may have stopped the rust. I am not saying that the sea foam is gods gift to man i use it mostly in the 2 stroke motors and they really do perform better. My 1962 Johnson purrs after adding a bit to the tank. weedeaters it also works well................ just saying, It's like OLe Blue when he takes his viagara after 4 hours he is not calling a doctor he's calling everyone!!!!!
NO i could not have driven it further because it rotted out ,,, They use lots of road salt, maybe i should have dumped it on the body and it may have stopped the rust. I am not saying that the sea foam is gods gift to man i use it mostly in the 2 stroke motors and they really do perform better. My 1962 Johnson purrs after adding a bit to the tank. weedeaters it also works well................ just saying, It's like OLe Blue when he takes his viagara after 4 hours he is not calling a doctor he's calling everone!!!!!
