Computer help---a little problem...
Old Jul 24, 2010 | 09:21 PM
referee54's Avatar
Our wireless keyboard has been shutting down on us---I put new batteries in, so that is not the problem...anyway, I purchased a new Microsoft wireless mouse/keyboard, and even after I loaded the software via CD, when I plug the wireless recognizer in, nothing happens. The Wizard pops up, but keeps telling me that the set-up was unsuccessful. Interestingly, though, there are shortcuts now on my desktop for settings to the mouse and the keyboard.
I still am running Windows XP--might this have something to do with it---drivers missing for USB, or what?
Tim C.
Old Jul 24, 2010 | 09:26 PM
DarkShadowSTX's Avatar
You were able to type this somehow.
Did you completely uninstall the old mouse and keyboard drivers?
Restart the computer after uninstalling?
Is the keyboard compatible with XP?
The software CD may also be out of date and you may have to go online to download the software from Microsoft.
Old Jul 25, 2010 | 12:51 AM
avfrog's Avatar
^ x2 Download current drivers.
Old Jul 25, 2010 | 04:23 PM
XP should not require any drivers for basic keyboard and mouse functionality. Go through the wireless connect sequence in the manual. Dunno what M$ uses, but with Logitech, I think it's this - press connect button on receiver, then keyboard, then receiver again, then mouse.
If you want the enhanced functions, load the software after you have connectivity.
Old Jul 25, 2010 | 04:27 PM
have you tried plugging it into another usb port?
Old Jul 25, 2010 | 07:19 PM
referee54's Avatar
I have tried plugging them into every open USB port---I did the device manager route and all of the USB's are functioning. I also did the Logitec stuff and pushed all of the buttons...I am using the old keyboard right now as it works from time to time...
TSC
Old Jul 25, 2010 | 07:59 PM
88rxn/a's Avatar
un-install the software and try it again?
Old Jul 25, 2010 | 08:16 PM
may want to open it up and ckeck your motherboard for any swollen or leaking capacitors. may have a mobo going out
Old Jul 25, 2010 | 08:28 PM
referee54's Avatar
Now that is the news that I certainly didn't want to hear, but it may be time for a new 'puter, period.
Old Jul 25, 2010 | 08:30 PM
JackandJanet's Avatar
Tim C.
The drivers won't be missing if you installed the software before plugging in the keyboard receiver, but they may not have installed correctly. If this is the case, you need to uninstall them and then let the PC try to install them again. You can uninstall them through Device Manager.
- Jack
Old Jul 25, 2010 | 09:40 PM
It may just be a driver issue but when these puters start doing strange things alot of times it the motherboard about to take a dump. Is it a Dell by chance?
Old Jul 26, 2010 | 02:00 AM
Lady Fitzgerald's Avatar
TSC
That sentence strongly suggests the problem is in your computer. Try borrowing another keyboard known to work and see if it works on your computer. If not it's either to the repair shop or to the new computer store. You might try the guys at How to Geek Forums for more advice. They have some pretty sharp guys over there. Tell them everything you told us here.
Old Jul 26, 2010 | 12:25 PM
TysonsLariat's Avatar
I have a wireless mouse that uses a USB plugin that looks like a thumbdrive. It would intermittently hang and drove me nuts. What I found was that the wireless part is a very low output RF broadcaster/receiver. The computer was jamming and interferring with the signal when I plugged the USB receiver into the back of computer. Placing the USB receiver next to or close to your mouse and keyboard may solve the problem. Simply running a USB extension may do the trick. My computer has USB ports in the front, on top, and in back. The one on top works the best for the wireless mouse.
Old Jul 26, 2010 | 01:55 PM
temper's Avatar
From: St Mary's County, MD. Home of the big forehead.
That's a bit of a stretch to suggest the motherboard may be dying just because his wireless keyboard won't work.
If possible, try plugging the wireless keyboard receiver into another computer without installing the software. As someone else suggested, it should work just fine. If it doesn't, then you probably got a defective product.
Try a known good wired keyboard on your computer. If you still have problems, then it could be a hardware issue with your computer or a problem with the operating system. To determine which is the culprit, you can download a boot disk from http://www.ultimatebootcd.com/ or http://www.knopper.net/knoppix/index-en.html and boot your computer up with either of those. If you still have problems while running under either of these operating systems, then it's definitely hardware.
