Oil Change Interval
Old Jun 5, 2010 | 08:58 AM
shotgunz's Avatar
Originally Posted by maddoughboy
Have you done the break in change yet? The other break in change that gets ignored is the diff, you should do both of these in about 1k after purchase. Most places will tall you about the oil but not the diff and I have seen some pretty bad diffs from not having this done, esspascialy if they have a speacial break in fluid in it.
Yes, both diffs since the front is still spining evevn when not in 4wd, but that wouldn't apply if you don't have 4wd.
After seeing what can happen to a diff when you don't do this what ever you I would spend what ever I needed to to do it, and keep from having to rebuild my diff and get a rental car, but then again good excusse for new gears.
Well this opens up a whole new can of worms. One more thing to worry about.
Do you happen to know the failure rate (failures/100 vehicles)?
Does it usually fail within the first 10k miles? 20K? 50k? 100k?
Is Ford denying waranty claims based on improper maintenance?
So do you think I would be safe if I changed both front and rear diff fluid every other oil change? Or would every oil change be better?
Old Jun 5, 2010 | 11:18 AM
Factory diff fluid and transfer case fluid is good for 100k.
Old Jun 5, 2010 | 01:56 PM
Raptor05121's Avatar
why is this in the GD?
Old Jun 5, 2010 | 02:04 PM
Because the OP decided he wanted to post it in here. You have a problem with that?
Old Jun 6, 2010 | 01:15 AM
maddoughboy's Avatar
I don't work at a dealership but a indebendent shop and most that I have seen failed around 50k-75k. Once you do the first one for break in you won't have to do it for 80k-100k. I had one that we replaced the diff in and it came back in 3k and it looked like the fluid had been in it for 100k we warenteied the fluid since it came in with in warrenty and the advisor didn't let him know that it needed to be done befor 80k.
Old Jun 6, 2010 | 01:58 AM
The factory diff fluid is good for 100k. However, when you regear with aftermarket gears, THEN you need to follow a breakin procedure which involves a fluid change at 500 miles.
Old Jun 6, 2010 | 10:40 AM
Norm's Avatar
Factory diff fill is good for 100K. It is a synthetic fluid. There is no need to change it sooner unless you are changing something like your cover. I switched to a Mag-Hytec cover so I changed my fluid but that was around 50K. Do not judge the fluid by appearance. If you have a LS you will have very foul smelling gray looking fluid. That is normal. Smell that tube of friction modifier next time you add one. It is bad smelling stuff.
Old Jun 6, 2010 | 03:14 PM
chris1450's Avatar
Your way old school. That isn't even close to true anymore. A good example is I just popped the diff cover off of my F-350 at 95,000 miles. Never has been off. The oil was great and there was no wear. Tooth pattern was great. The problems you see with differentials has NOTHING to do with the factory oil. There is no such thing as break in oil anymore. My focus has 110,000 miles and right from the start new I have changed the oil every 5k because that is easy to remember. And I am changing it too often. The oil can easily go 7,500 miles with my driving habits. The car still runs like it was new.
