building a new computer
Here's the next PC I'm going to build. It's going to cost around $250.
http://www.instructables.com/id/Buil...ntendo-NES-PC/
Some Pictures:
http://img198.imageshack.us/g/img2409t.jpg/
The only problem I can see with this build is "HEAT"....
Some Pictures:
this is what im looking at now. do you think my cool master power supply will run it. my wife will kill me me if i speed much more
http://www.newegg.com/Product/Produc...82E16813128435
http://www.newegg.com/Product/Produc...82E16814127490
http://www.newegg.com/Product/Produc...82E16819103849
two stick if ram
http://www.newegg.com/Product/Produc...82E16820148221
http://www.newegg.com/Product/Produc...82E16835233029
http://www.newegg.com/Product/Produc...82E16832116758
two stick if ram
You don't say what watts the CM power supply is. I would suggest at least 650 watts unless you go dual (SLI) graphics cards. Then I would suggest at least 850. Also, if you are going to run Win 7 64 bit, I suggest 2 more sticks of that memory.
You might also look at the new Nvidia GTX470 or 480 (more expensive) graphics cards. From the reports I have seen, they are blowing away just about anything ATI has right now.
This is the one I currently have.
http://www.newegg.com/Product/Produc...82E16814130549
He said hes already spending a lot, adding a 470 would add $200. A 5770 will be enough.
I assume you are reusing the case and hard drives. Also we need to know how many watts the CM psu is. If its 550w+ you should be fine.
Heres a 1090T + UD3H combo. Saves $20. Check out the combos before you buy also.
For RAM I would recommend some of these.
How set are you on the 1090T? You could just OC a 1055 and itll save you $100.
Also if you have a Frys near you. Only $265 for a 1055T and a UD3H ($330 on Newegg).
my current ps is a coolmaster 500 watt. here is the case im buying
http://www.newegg.com/Product/Produc...82E16811119213
i just bought a 1tb harddrive 6 months ago. i will run windows 7 pro 64 bit
My I7 has that case. Good BIG case and very quite considering all the fans it has on it. I wish it had more hard drive space though, only 5 slots.
My 750watt power supply just isn't cutting it anymore since I added the two additional WD black 1tb drives. I'm waiting for a deal on a modular 1000w power supply to come along.
two stick if ram
two stick if ram
i bought everything i posted. here is the motherboard and cpu http://www.newegg.com/Product/ComboD...D=3196498&SID=
