E-85 feels like more power....
As first stated in the post this was not a question of efficiency, but in terms of increased "power" i.e. better acceleration. I have enjoyed reading these well constructed responses thus far.
Is it safe to say at this point in time that perhaps E85 is producing more power at a lesser efficiency?
And maybe I do not need to get my butt dyno recalibrated afterall ?
More power from E-85?? You may need to get your butt dyno recalibrated.
Now if you put a blower on the engine, you DO increase compression.
- Jack
Of course, you were feeling the power during acceleration, where it is likely that neither engine would be operating at stoich, both would be rich. But, my guess is the "rich" difference would be nearly identical between the two charges.
I DO think you felt greater power.
- Jack
No, I think your "butt dyno" may well be calibrated correctly. In just a cursury search for information, I'm reading that E85 has approximately 72-75% of the energy per gallon that real gas has. Now, if two engines run at stoich, the difference in quantity of fuel used burning E85 is approximately 33.6% higher per cylinder charge than you have using real gas. So, this means that the 28-25% drop in energy is more than made up by the increased fuel charge.
You're just going to have shorter range.
- Jack
- Jack
The range is surely less, it was neat to see the computer show the adjustments. As I mentioned earlier the display for miles till empty jumped from 401 to 355 in a mile or so then it leveled out. It would have sucked if I did not expect it to do that.
Jack, we are definitely on the same page. What would be REALLY nice is an engine with a variable compression ratio - if the compression were to increase with the higher octane fuel, you would REALLY notice better performance - and probably gain some fuel mileage back too.
Interesting Read GLC
I think that may be very safe to say.
I was listening (on the radio) to the researcher who directed the Human Genome Project a few days ago and he's just founded a new venture that is in partnership with Exxon-Mobile to determine if it is feasible to produce biofuels from algae. Some of the advantages he talked about were that the algae essentially produced the fuel on it's own, without any additional energy consuming input like refining, that it will grow anywhere, not just in prime farmland and that it seems to have the potential of producing 10 times the fuel per acre "farmed" as corn. He called corn ethanol a "disaster", which I've believed it to be for a long time.
He said we could expect results within 5-10 years, barring huge setbacks. I'm hopeful.
I've enjoyed this discussion gang. And again, Labnerd, thanks for correcting me on the "lead" thing.
- Jack
Whatever advantages could come from ethenol. I do not like the fact we would be depleating our farmland and ruining the soil to grow fuel.
I'm not green by any means, but the soil can only produce so much, then we have nothing to grow our food with. Our farmland will end up worse than the dust bowl, or the Sahara.
Agreed!
Save the corn for cows, chickens, and people!
