Running E10 in an airplane?
Old Oct 9, 2008 | 10:55 PM
Raptor05121's Avatar
Well to cut this short, my dad's PA-28-140 Cherokee has a STC to allow it to run on autogas. 100LL is hovering on $5.53/gal, so there is NO way I'm dumping that crud into the tanks. I'm going flying this weekend. I'm wondering wether I should pay $3.35/gal and get E10, or pay $3.65+ for pure unleaded. Keep in mind this plane has two wing tanks, of 27-ish gallons each, so filling it will be over $250. I'm worrying about the long-term harshness of the ethanol on my fuel lines zigzagging through the wings and ****pit, etc. Def don't want to be replacing those next annual. I'm also wondering on how this will affect the engine. It is a O-320A low compression, wide flange model. I'm wondering what ethanol will do to carbon buildup on the mags, exhaust temps, and so on. Thoughts?
Old Oct 9, 2008 | 11:09 PM
Screw50's Avatar
Raptor, check out this EAA wesite. Stick with the non ethanol.
http://www.eaa.org/news/2006/2006-11-01_faa.asp
Old Oct 9, 2008 | 11:11 PM
chris1450's Avatar
what does the STC say about ethonol? There should be plenty of info on it.. the FAA is ridiculous with regs. I wouldn't use it if I were you. If you fly in colder weather you may find freezing problems as ethanol is hygroscopic. I know you purge your tanks of water before every flight... but still.. I wouldn't take the chance. Your talking about $15 difference on a fill up.. I wouldn't sweat it.
Old Oct 9, 2008 | 11:20 PM
S-76's Avatar
+1
X2
Old Oct 9, 2008 | 11:46 PM
06yz250f's Avatar
its your DADS plane. if you screw it up im sure he will kill you. spend the extra money.
Old Oct 10, 2008 | 03:35 AM
Not only should you not put E10 in it, you should have a test kit to make sure the supposed pure gas really is pure gas. Alcohol in avgas is bad news.
Old Oct 10, 2008 | 11:13 AM
stich's Avatar
I've had my plane for the last 10 years and it also has the STC for auto fuel. I've never run it and unless it's an emergency, I never will. Like it was said, only another $15 per fill up for the 100LL. My planes a 1960 Cessna 175 with the GO 300 six cyl. Continental engine.
