Extracting .bin files ??
Old May 14, 2008 | 03:35 PM
ThumperMX113's Avatar
Alright guys I need some computer help. Someone told me in my other thread about wireless routers that I should try updating my firmware on my Linksys Wireless Router. Well I followed their link and did all of the stuff. My model is the WRK54G. Anyways, I downloaded the firmware but I can't extract the file. I downloaded Winzip, it didn't work. I downloaded this program called AlZip and when I try to extract the files I get a message saying "Error: Invalid Archive". I can't update the firmware without extracting the files so can someone help me out? I'm getting my internet speed increased today after 5:00 so I wanted to update the firmware before to see if it helps.
Old May 14, 2008 | 03:40 PM
malexander52's Avatar
Burn it
You need to burn the file to a CD using Nero or a program that will can create ISO (image) CDs. The following links give a brief explanation of the .BIN files and how to use them.
http://www.tech-recipes.com/rx/696/h..._cue_iso_files
http://www.iceteks.com/articles.php/binfile/1
I hope these help!
Good luck with the back!
Old May 14, 2008 | 04:07 PM
Originally Posted by CrAz3D
I thought that you just opened the .bin file from your router's admin page.
Ya but the file needs to be extracted first.
Old May 14, 2008 | 04:13 PM
Needs to be extracted from what? a .ZIP file? If so, the builtin XP unzipper or Winzip will work fine, if you are getting an error, you have a corrupt download, try again.
Old May 14, 2008 | 04:25 PM
BlueFlareside's Avatar
Magic ISO will extract it.
http://www.magiciso.com/tutorials/miso-whatsimage.htm
Old May 14, 2008 | 04:53 PM
Norm's Avatar
If it is already a .bin you do not need to extract it.
Old May 14, 2008 | 05:36 PM
It wouldn't work. I bought a D-Link N Router. I wanted to switch to N and this gave me an excuse.
Old May 14, 2008 | 09:48 PM
esf's Avatar
esf
I hope these help!
This is correct. Open it with your cd burning software such as Roxio or Nero or similar. Or you can mount it (like burning to cd but instead of a cd it's your hard drive) to your hard drive using something like Power ISO or similar. Then just use the cd you burned to install whatever it is you're installing. There should be another file with the .bin. The .bin file instructs the burning software on what to do with the other file.
Old May 14, 2008 | 10:09 PM
Larry227's Avatar
the other file you mention is a .cue file and it's opposite what you said. The .bin is the files and the .cue tells your burning software what to do. Something like that. At least that's how it works with movies. If this is different and I'm wrong then it won't be the first time.
Old May 15, 2008 | 12:32 AM
I just checked the Linksys site (but this is now a moot point) - the firmware file does in fact download as a .bin, nothing has to be extracted. The .bin is used directly in the firmware updating utility, it is not any kind of image that has to be extracted such as an .iso or .bin/.cue pair.
Smart move, Thump - the WRK54G is a POS. It's a stripped and cheapened WRT54G, it even only has one antenna. It's a weakling.
Old May 15, 2008 | 12:35 AM
I tried to update it with that file and it wouldn't work it came up with an error. I searched on google and found a bunch of people with the same problem. I didn't think I was doing something wrong until a retard at Linksys told me it needed to be extracted ... than offered me to buy a extended service plan for $40 so they could walk me through it. I said I can buy a new router for $20 more and he didn't have much to say.
Old May 15, 2008 | 11:00 AM
Raptor05121's Avatar
WinRAR and Magic ISO will do it
Old May 15, 2008 | 01:04 PM
Norm's Avatar
No it won't. Firmware .bin files are already extracted.
Old May 15, 2008 | 09:50 PM
esf's Avatar
esf
Heh. Yeah same here. I always get it backwards without looking at it. I just open the one that's smallest. But apparently it doesn't matter because this entire situation is different.
