sand rail engine swap help
Here is a picture of my sand rail so you know what im dealing with.
I want to put a new style subaru engine or something in it. I know ive seen it done, but dont know what year engine fits in it. any help would be great!
its street legal, but I want more power, and im sure a turbo engine would be a lot more fun.
That looks like fun, but I think you need more trailer.
From what I can recall, you are probably going to have a lot more options and good deals if you stick with the VW flat four. Look into Type 4 engines.
http://www.tunacan.net/t4/links.htm
I'd stick with the VW. You already have mounts for it, you know the trans will bolt up, and you can build those things to be REALLY fast. The other thing to need to look into is the transmission. I'm running a semi built type1 trans with a corvair flat 6 motor and I cant put much more power down before I have trans issues. If you run a turbo subie motor, you'd goign to need ALOT of trans to keep up with it. What engine is in there now?
alon vws don't have engine mounts they just bolt to the tranny
there are kits out there to do the swap I'd look them up but I'm using my iPod right now because I'm out of town
and here is a place to get an adapter to bolt a subaru(and many others) to a vw transaxle
http://www.kennedyeng.com/vw_por.htm
