Old Sep 14, 2015 | 02:15 PM
  #99031
The truck has 12 quarts of new Motorcraft LV Transmission Fluid, New Motorcraft Transmission Filter, 75w140 rear end fluid, 6 quarts of Pennzoil Ultra and a MC Filter along with some wiper blades. Still had the original blades on from when the truck was new. Figured i might as well go back with the ford ones since they lasted so long. Cleaned all the map sensor's a few days ago . The ol truck should be happy for a while.
Old Sep 14, 2015 | 02:16 PM
  #99032
NFLD FLARED 281's Avatar
Originally Posted by 88racing
Sorry to hear that news...hopefully her health turns around in the right direction
But it won't :/
Thanks though
  #99033
Need some ramps for your pick-em-up truck
Yep, need to do some measuring. This tractor is bigger than most riders, may even be too wide. It's 7 ft long.
Old Sep 14, 2015 | 02:36 PM
  #99034
With all the property you have between Burleson and East Texas, I'm surprised you don't have a trailer.....
I would love to have a medium-sized trailer myself, but would have to rent a spot to store the dang thing so it's just not worth it to me. I have a bunch of old gutter's I'd like to cut up and take over to recycling right now but I don't want to haul them in either of my two trucks since neither are daily drivers and the beds of both still have unblemished factory paint!
It's times like this that I miss my old '97 Ranger......
Old Sep 14, 2015 | 02:42 PM
  #99035
Question
So I started messing with the brakes on the LTD today and am a little confused.
The last time I drove it, I could have sworn one of my calipers was hanging up, since the driver's side front wheel was REALLY hot and giving off a funny smell when I parked it. I jacked it up in front this morning and found that the wheel was now free. I fully expected that once I started the car and applied the brakes, the caliper would probably freeze-up again and I wouldn't be able to spin the wheel. However, after taking it for a 4-5 mile run down the road, the wheel still seems to spin free and I can't replicate the "soft" pedal" I had the last time I limped it home.
Any ideas, guys.....
Old Sep 14, 2015 | 02:45 PM
  #99036
I have a 16' two axle but it is loaded with trees and brush that needs to be hauled off. Plus the floor needs to be replaced. I need to buy a 6x12 single axel to haul the mule and small stuff.
Old Sep 14, 2015 | 03:12 PM
  #99037
I'd recommend a little further drive than 4-5 miles..
Old Sep 14, 2015 | 03:46 PM
  #99038
Contaminated brake fluid (moisture) will boil while driving with engine heat, boiling water expands, applies brakes locally, even to the point of a single wheel doing full lockup while driving if the brakes are strong enough.
Maybe it's a wheel bearing issue, causing the drum/rotor to get hot, then giving you soft pedal due to brake fade with heat
Jus t my .02$
Old Sep 14, 2015 | 04:33 PM
  #99039
Jus t my .02$
This...
Old Sep 14, 2015 | 04:35 PM
  #99040
Sounds good.....
Hopefully all that service didn't hit you too hard in the pocketbook
Old Sep 14, 2015 | 05:32 PM
  #99041
Jus t my .02$
That sounds like a very plausible scenario given the fact that the brake fluid in the car is 28-year-old factory issue! I'll flush the system and then take it on a good 25-30 mile run to see if I can recreate the performance issue.....
Old Sep 14, 2015 | 05:37 PM
  #99042
Sounds good.....
His pocket book won't even notice it.
Old Sep 14, 2015 | 05:45 PM
  #99043
Got an owie on my finger....
And on my arm....
Old Sep 14, 2015 | 06:21 PM
  #99044
The first one happened while trying to remove a spring perch....the drive chisel slipped and so did my finger onto the top of the drive head while the hammer was coming down....
The second one happened while fabbing a bracket asking too much of a cut off saw....the metal bound then got richocheted off the back guard into my arm
Old Sep 14, 2015 | 06:31 PM
  #99045
88 -- your career as a hand model is officially over.....
The worst thing I usually get with my job is slivers from handling sheets of OSB -- but those little buggers hurt! Of course, I could always fall off a roof if I'm not careful -- hope I didn't just jinx myself.....
