Old Sep 28, 2011 | 02:01 PM
  #67231
jbrew's Avatar
Originally Posted by harleydude78
Thanks a bunch for that info! I had no clue when they fixed the plug issue. Thats one of the things making me nervous about looking at used 05-08 F150s
No problem. The way you can confirm if unsure, take a peak at the boot tops. Updates/New style have brown boots. Older versions are all black.
Brown, -should be easy to spot since there's a reveal before disappearing in the plug chambers.
Like this -
Old Sep 28, 2011 | 02:06 PM
  #67232
jbrew's Avatar
jbrew, you didn't run out and do that console/cooler conversion did you?
Hmmmm.....Console cooler conversion ? Huh, nope. Actually, you lost me
What, - did someone become inventive?
Old Sep 28, 2011 | 02:11 PM
  #67233
dsq3973's Avatar
Might be going to Canada for two weeks of training. Then I will have to go back for a week later on. Will be making $8000 more a year and will be a level 5 millright.
Congrats Randall, that would be a really cool experience. Where in Canada would you be going?
Old Sep 28, 2011 | 02:13 PM
  #67234
Read all the posts.
https://www.f150online.com/forums/20...onversion.html
Old Sep 28, 2011 | 02:56 PM
  #67235
Like this -
Like this.....
Old Sep 28, 2011 | 03:10 PM
  #67236
Couple of plastic bags work the best......pull the water out with the bag dump it and there's your garbage bag for the empties.......
Old Sep 28, 2011 | 03:14 PM
  #67237
Now that will work!
Old Sep 28, 2011 | 03:25 PM
  #67238
Some things I dislike about my 2011:
Poor visability out the back glass due to the taller and larger head rests on the back seat.
Poor visbility out the door window due to repositioning of the B pillar.
Can not turn the air cond fan completely off. Positions are 1-4.
Poor head lights
All door/window switches are reversed and makes switching back and forth from the 05 a pain
The blinker/bright set up is rediculous. half the time when I quickly turn off the brights, I turn on a blinker. Much too sensitive.
The front air dam is so low, you have to be careful of dips.
Had to get the sliding back glass to get the other things I wanted. Package deal.
The jack is lacated under the seat in the middle of the truck. If you are loaded down in the rear floor area and have a flat, would have to remove a lot of stuff to get to the jack.
Old Sep 28, 2011 | 04:23 PM
  #67239
Poor head lights
Yep.....almost the same complaints about the sport track.....
Old Sep 28, 2011 | 04:24 PM
  #67240
Originally Posted by 6"_isnt_enough
i like telling my co-workers "im in a meeting" while i sit here on f150online all day lmao
Slacker....
Old Sep 28, 2011 | 05:07 PM
  #67241
The next truck I buy will not be new, I can tell you that. I don't like the quality and the looks are ehh. I'll keep mine, have a commuter car and down the road pick up an old 7.3 or a Dodge with the Cummins and I'd rather have the Cummins to be honest. I love Ford, but they are putting less effort into quality and more into electronic crap.
Old Sep 28, 2011 | 05:28 PM
  #67242
Why doesn't it have a front plate? Out of statie?
Originally Posted by Micheal
I've read somewhere that they are letting some of the sports cars not have hem anymore. Not sure where I read it at but have seen that. Also not sure of the cedibility of the read.
As far as i know, its still required on all cars in Tx. That being said, about 70% of my customers at work do not have a front plate. In general, its one of those things that they just use to pull over a suspicious vehicle to check it out, unless you get a total asshat cop he wont get you for just that.
FWIW, i dont have a plate bracket for my STX valence, and didnt run one for two years it was on the truck
You charge me a lot more than beer!
Money can easily be converted to beer
Old Sep 28, 2011 | 05:35 PM
  #67243
I thought the same thing when we got Sarah's new Escape, but there is a separate power button right in the middle of the control head
if yours looks like this it would be pushing the center of the lower left ****
you can wrap the jack in a towel, and put it inside the spare tire wheel if its mounted face down.
Old Sep 28, 2011 | 05:49 PM
  #67244
Thanks, I'll check that out. That looks very similar if not the same.
Old Sep 28, 2011 | 05:52 PM
  #67245
Three more things:
The key fob is backwards from my 05 and plus both sides feel the same. So in the dark, I am punching all over the thing to unlock the truck.
They do not have a true black and I do not like Tuxedo Black.
It has a wider turning radius, I suppose due to being longer.
one more, the sheetmetal is even thinner and more flimsy.
