Old Aug 13, 2011 | 10:50 AM
  #65101
Originally Posted by jbrew
Still haven't found it ?? You got any hair left ? That would be driving me crazy..
Yeah, it's quite the irritation.
Old Aug 13, 2011 | 10:52 AM
  #65102
Will have you tried rotating tires front to back? could be slight uneven shoulder wear causing that noise that sounds like bad bearings.
But nevermind you have a "pop" sound not a grumble type sound
Yeah it's a single pop on flat terrain turns that gets multiplied into successive pops when turning into a sloping driveway.
It's got me... :o
I do research and read and watch vids, and it sounds like this, then it sounds like that. Now it sounds like I'm nuts! :o
I wonder if it's the strut bearings... I know those can go out. if I do those I'm going to replace the front Eibachs with something e lseat the same time.
Old Aug 13, 2011 | 11:55 AM
  #65103
jbrew's Avatar
It's got me... :o
What would pop like that ? A tie rod ? Or yea, sway bar links, they can get stuck and bent when broken.. It's a 2wd, - doesn't it have cams for alignment ? Maybe a loose cam (the rear). (?) I guess it could be a bearing, if the cage is screwed up.
I guess you can't get it to pop stationary. Iduno, I'd have everything apart by now lol.
Old Aug 13, 2011 | 11:56 AM
  #65104
jbrew's Avatar
Shocks ?
Old Aug 13, 2011 | 12:30 PM
  #65105
Things I've already replaced up front are:
lower ball joints
upper ball joints
outer tie rod ends
inner tie rods
sway bar end links
hub/rotor
I've also checked every nut and bolt that can be checked.
Everything that I've replaced has needed replacing.
Old Aug 13, 2011 | 12:44 PM
  #65106
jbrew's Avatar
Geezzz, you already did all that lol.
___________________________________
Hey, I'm getting the impression this guy isn't retaining my information correctly (?) -
https://www.f150online.com/forums/19...7-f250-ld.html
Friendly fellow, we are going to be good friends
Old Aug 13, 2011 | 12:53 PM
  #65107
Yeah I know, that's why I'm going to visit Pat sometime so we can figure this out. I'm all guessed out.
Old Aug 13, 2011 | 01:18 PM
  #65108
dsq3973's Avatar
Will, what about A arm bushings??
Old Aug 13, 2011 | 01:22 PM
  #65109
They're tight and look good still.
Old Aug 13, 2011 | 01:25 PM
  #65110
dsq3973's Avatar
Are they Urethane or the stock rubber ones?
Old Aug 13, 2011 | 01:30 PM
  #65111
jbrew's Avatar
Yea, if your using a lubricant on those, use silicone based. But, you really shouldn't need it, since lubing is mainly for squeaky bushings, resulting from dusty conditions.
Old Aug 13, 2011 | 01:35 PM
  #65112
They're stock.
Old Aug 13, 2011 | 01:38 PM
  #65113
dsq3973's Avatar
The urethane bushing kits that I have seen all recomend being greased and on the critical bushings they come with grease fittings.
Old Aug 13, 2011 | 01:39 PM
  #65114
dsq3973's Avatar
They're stock.
Ok, scratch that off the list.
Old Aug 13, 2011 | 01:42 PM
  #65115
jbrew's Avatar
I've never seen Urethane's or Moogs with zerk fittings. That wouldn't be a bad idea tho, - I just haven't seen those.
