Old Aug 2, 2011 | 02:27 PM
  #64291
dsq3973's Avatar
Just make sure they are clean and give them a good wipe down with Acetone or something like PPG AcryliClean, then spray them with adhesion promoter if you are color matching or just spray them with Krylon Fusion. As far as the clear is concerned you can do it on the cowel but I wouldn't bother on the bed rails they get to much use/abuse and for what a can of Krylon cost's compared to an automotive clear you are cheaper to spray them a couple times with Krylon. Just tape off everything really well you don't want overspray on and do not paint when it's windy you will only have problems.
If you can get a garage or shop to do it in I would go that way and if you do get overspray on the paint just keep a clean rag and the AcryliClean handy and wipe if off while it's fresh. The only reason I suggest the AcryliClean is because it's pretty paint friendly as long as the paint is cured and I use it all the time to for decal installs and my painting projects it's pricey but it's well worth it and I keep a gallon in the garage at all times. Also get some Nitrile gloves so you don't accidently touch the plastic once you have already wiped it down and nothing will **** you off more than getting the job done and noticing the paint starting to lift in the shape of a finger or palm print also pick a spray can handle they make life so much easier and they are only about $4-$5.
Old Aug 2, 2011 | 04:39 PM
  #64292
06F150STX's Avatar
It's 116* right now with the heat index of 122*. This is crazy hot here.
Old Aug 2, 2011 | 04:44 PM
  #64293
dsq3973's Avatar
That sucks Randall, stay cool and hydrated bud......
Old Aug 2, 2011 | 04:51 PM
  #64294
Keep cool...88° here with a heat index of 104°
Old Aug 2, 2011 | 05:07 PM
  #64295
I thought we established that Bud does not hydrate.
Old Aug 2, 2011 | 05:29 PM
  #64296
06F150STX's Avatar
I had my share of water today. Now its time for some Bud in the A/C in my house.
Old Aug 2, 2011 | 05:31 PM
  #64297
I have RR in the fridge in Burleson and I have BL in the fridge in Brownsboro. I'm all set.
Old Aug 2, 2011 | 05:35 PM
  #64298
06F150STX's Avatar
Looks like the company I work for now is about to buy me some new head light housing
Old Aug 2, 2011 | 07:03 PM
  #64299
MTM Ford's Avatar
Just got the mail. My inlays were in there Going to paint the badges and put the inlays in this weekend.
Old Aug 2, 2011 | 07:43 PM
  #64300
Originally Posted by shifty219
Sorry guys for the newb style question Anyways more info on the motor from what the owner informed me is that it is a 454 bored out to a 502. The plug is welded in at the back of the intake by the dissy. The only thing under there is the lifter valley. From what I seen from the tear down, it has been played with and knew of the water leak because all the silicon used on it. I just cant think why they would drill a hole in the intake then weld a plug back in? And also the intake was milled down a full 1/4 inch making it sit to far down in the valley.
what kind of computer system runs it, or is it carbed?
it could be a water temp sensor, or MAP sensor originally as well. MAPs are usually mounted on the back of the manifold like that. It could be a newer 454 that was FI with a MAP and converted to Carb.
Stupid hot today, gonna be stupid hot tomorrow.
Old Aug 2, 2011 | 08:03 PM
  #64301
Mucho Caliente over here too!
Old Aug 2, 2011 | 08:15 PM
  #64302
dsq3973's Avatar
It's to humid to paint.....
Old Aug 2, 2011 | 08:21 PM
  #64303
Been rainy here this after at the campground. Two thunder storms, one with lightning and raining again now
Old Aug 2, 2011 | 08:36 PM
  #64304
Old Aug 2, 2011 | 08:45 PM
  #64305
ian51279's Avatar
I'd really hate to drive across the state of TX according to that map.
