Old Jun 9, 2011 | 09:27 AM
  #61336
dsq3973's Avatar
Glad your ok and no one got hurt Jim.
Old Jun 9, 2011 | 09:31 AM
  #61337
Originally Posted by 88racing
What ones you getting?
Same ones?
S/B p0420,0430. Cat inefficiency codes. Cats are quite small. I didn't pull them as I saw the light right when I got to work.
Old Jun 9, 2011 | 09:46 AM
  #61338
You guys who run magnaflow 94106 cats. Where are your rear o2 sensors mounted?
Old Jun 9, 2011 | 10:59 AM
  #61339
Emailed Bill at PHP to see what he can do about the cat codes.
Old Jun 9, 2011 | 11:02 AM
  #61340
jbrew's Avatar
Well, metal washers if it's the O2 bungs. I'm betting it is and you lost the seal in the bungs. Still can't believe new bungs are leaking that bad. Not a big deal if it is, -do it the same way as you did before, just fab up a washer to cap that bung. Get the ID of the washer as tight as you can, even if you have to thread the O2 thru it (that's tight!). That will work, uhh honest. -
Before anything, you need a bubble test to confirm.
The washers don't need to be heavy. Find some lighter gauge w/smaller ID centers that you can drill out easy to the size you need. I'd use stainless tho.
_______________
Do you think it might be leaking at the flange connections up by the collectors ?
Old Jun 9, 2011 | 11:15 AM
  #61341
I don't know honestly. I'll have to check for leaks again.
Old Jun 9, 2011 | 11:17 AM
  #61342
We looked when we cranked it up and they looked like they weren't leaking. I'll have to check the small things first I guess...
Old Jun 9, 2011 | 11:54 AM
  #61343
Bill said he'd turn he rear o2's off for me, free of charge.
Old Jun 9, 2011 | 12:05 PM
  #61344
Other than that, did Bill indicate there was a need for any program changes needed due to the headers being installed?
Old Jun 9, 2011 | 12:07 PM
  #61345
No, he said things were fine and there was not a significant enough gain to warrant new custom tunes.
Old Jun 9, 2011 | 12:22 PM
  #61346
Interesting. I would have thought there would be.
Old Jun 9, 2011 | 12:29 PM
  #61347
I'll take his word for it. Truck runs great, just a bit loud right now. lol
Old Jun 9, 2011 | 12:56 PM
  #61348
Yes, I take his word for it. Just surprising to me.
Old Jun 9, 2011 | 12:57 PM
  #61349
jbrew's Avatar
That's cheating. He's a bad influence lol.
Well, should at least double check it anyway. Turned off or not, you don't want that Y leaking to much. Something miner will most likely seal itself in time, but, - uknow what I mean....
So, are you charging up the video camera ? Plug it in, -it's almost time.
Old Jun 9, 2011 | 01:27 PM
  #61350
Well I'm going to get the piping welded up at some point so the clamps will be gone.
