Old Apr 9, 2011 | 06:28 AM
  #58216
Welcome back to the good state, TJ.
Old Apr 9, 2011 | 06:36 AM
  #58217
Nothing screams poor craftsmanship like wrinkles in your duct tape.
Old Apr 9, 2011 | 07:12 AM
  #58218
Old Apr 9, 2011 | 09:28 AM
  #58219
dsq3973's Avatar
Welcome back Jereame.
Old Apr 9, 2011 | 10:10 AM
  #58220
Off to the postoffice, get the truck serviced and then mow. Washed the truck last night after we got in. Got a lot of cleanup to do, the oak fronds and pollen are a mess!
Old Apr 9, 2011 | 10:22 AM
  #58221
shifty219's Avatar
Morning all
Old Apr 9, 2011 | 10:31 AM
  #58222
It's drilling now.....
Old Apr 9, 2011 | 10:34 AM
  #58223
Originally Posted by MTM Ford
Oh well. If the wifes happy everyones happy.
Your wife must know my wife....same here..
  #58224
dsq3973's Avatar
Going to finish my gauge install today but I am a little nervous drilling into the exhaust manifold for the pyro probe.
Old Apr 9, 2011 | 10:35 AM
  #58225
dsq3973's Avatar
Same here.....Happy wifey, happy lifey.
Old Apr 9, 2011 | 10:52 AM
  #58226
shifty219's Avatar
Just dont drill into the turbo.... That might be a lil on the pricey side to replace
Old Apr 9, 2011 | 10:54 AM
  #58227
dsq3973's Avatar
I know, I am worried about a shaving getting sucked into the turbo and everyone says to drill and tap it while it's running but I am still nervous.
Old Apr 9, 2011 | 11:08 AM
  #58228
shifty219's Avatar
Really? hmmm, if you drill it dry use a shop vac by the bit to suck as much as the shavings away and use low speed as you are about to punch through the manifold. Less finer shavings on low
Old Apr 9, 2011 | 11:17 AM
  #58229
dsq3973's Avatar
Yeah, the theory is the positive pressure in the manifold will push the shavings back out of the manifold instead of sucking them in. I am planning on taking it slow and easy.
Old Apr 9, 2011 | 11:59 AM
  #58230
shifty219's Avatar
Ahhh yea, in theory it will work. Id run it once you got a good hole started. The shake from the motor will prolly give you grief trying to start the hole. Even too soak the bit in oil before you drill through, the shavings should sick to the bit.... should haha
