Old Mar 31, 2009 | 12:20 PM
  #15856
Jditta's Avatar
spent 100 bones at walmart
Groceries?
Old Mar 31, 2009 | 12:21 PM
  #15857
Originally Posted by Jditta
Groceries?
Probably truck cleaning supplies!
Old Mar 31, 2009 | 12:22 PM
  #15858
Jditta's Avatar
I always tell myself no when I want to buy that much cleaning supplies.
Old Mar 31, 2009 | 12:23 PM
  #15859
groceries, beer, oil/filter, wiper blades, hand cleaner
Old Mar 31, 2009 | 12:24 PM
  #15860
dsq3973's Avatar
You should try spending 200+ on an order from Auto Detailing Solutions.
  #15861
speaking of the truck, ive already put 650 miles on it, and ive only owned it for 7 days now
Old Mar 31, 2009 | 12:26 PM
  #15862
Jditta's Avatar
Couldn't do it. I MIGHT could pay that much for just beer though.
  #15863
dsq3973's Avatar
It doesnt take long. I think when I first got this one I put about 2500 on it in 3-1/2 weeks and then the dealer had it for a month.
  #15864
Waco twice?
Patrick, have you done the shocks on an 04+? To get the springs out, is it better to knock the ball joint out or take the tie rod off?
Old Mar 31, 2009 | 12:28 PM
  #15865
Jditta's Avatar
Waco twice?
I think tie rod
Old Mar 31, 2009 | 12:31 PM
  #15866
I think tie rod
I've seen a write-up saying each way. Not sure which is better, and if one is more likely to need an alignment than the other.
Old Mar 31, 2009 | 12:32 PM
  #15867
I havent no, usually tie rods are easier to pop off. Back the nut loose, and have it on by two threads, then hit on the nut to pop it out.
again if you put everything back together as it was, and dont mess with the tie rod adjustment you shouldnt mess up the alignment you already have
Old Mar 31, 2009 | 12:35 PM
  #15868
That sounds almost like how you take the ball joint apart. Back off the nut and whack the A arm a couple of times, then the nut if that didn't do it.
Old Mar 31, 2009 | 12:36 PM
  #15869
all the same basic concept, tapered hole you have to break loose
Old Mar 31, 2009 | 12:37 PM
  #15870
Zaairman's Avatar
Been there, done that. Still don't have enough stuff.
I put over 1000 miles on my F-250 the first week I had it...
