Roush Mustang 427R - worth the $$$... ?
Originally Posted by naplesbill
That 427R will run circles around a GT500. The Roush is an all-around package. The GT500 suspension is virtually the same as a regular GT. The GT500 is an overrated overpriced collectors car. The 427R was made to be driven and driven hard. I would take a Steeda or Roush Mustang over the GT500 or Saleen anyday. This is coming from someone who sold their '06 GT to buy my current F150. I have spent hours on hours reading up on all the performance Mustangs and believe me, if you do the homework, the Steeda and Roush are definitely the best.
If money was no object I would be buying a gt500SS with 720HP, to bad there is no way in hell I could afford it.
Originally Posted by birddog_61
A stock gt will take turns as fast as I want to, I am not concerned about doing 125 around a corner. I want to go fast straight, and the gt 500 is the fastest at that. Plus you can easily change the suspension on the gt500 and still have the Shelby and outrun the other ones in the corners too.
Not to mention, the suspension improvements encompass way more than cornering. The S197 is a solid axle and that causes inherent issues in handling. This includes going in a straight line. The Roush and Steeda suspension packages do an outstanding job of taming the live axle and it is street and track proven.
The 500 may have the same strut/solid axle setup, but spring rates and sway bars are different, plus the 4 vented discs will bring you to a halt. But the 427R can't "run circles" around what it can't catch. And a stock 3v Sohc 4.6L, with the cheap powdered metal rods with a roushcharger bolted on vs. a Built 5.4 Dohc, that is setup just for the Eaton that sits between the "V". The choice is clear to me, the 500 is def. a better car, and value.
Originally Posted by joshmac4.6
Overpriced???? 500 hp 5.4L DOHC 6 spd, with a base price of $42,000. 420ish RWHP stock?? And the quoted gains by K&N of 57hp have been proven, close to 50hp from just a intake. Overpriced????
Watch the video I posted and then find me a roush putting out those numbers with just the mods that car has. Even if you could find one it would be much closer to its limit than the 5.4 is. Im not saying the roush isn't a bad *** car, but the dohc 5.4 has much more potintial than the sohc 4.6.
$7000 is alot of cash, the 500 is priced around $42-$43k(compared to $50k), thats a plenty to send that little roush packing. And I don't know where you are getting your info that a SOHC will outperform a DOHC, but it's a little off. And with a good set of meats, the 500's are running 4.4's-4.6's stock, and throw in $2000 for a tune and light mods, and your going to be 500+rwhp, keep up in the roush. And with the other $5000??? Well you can only imagine the results.
