KDX 200 rehabilitation?
I've got a 1994 KDX 200 that I haven't even cranked in close to 10 years. While I know a lot of you will think that's a crime, I was hoping some of you moto guys could help me out.
I want to get the bike running again - it was running fine when I garaged it all those years ago, but has just been sitting since then. Can anyone give me an idea of what I'll need to do to get it cranked and running? I did most of the maintenance myself way back when, but don't really know where to start...
Any outside resources I should check out (good KDX/Kawasaki forums, etc.) would be appreciated as well.
Thanks in advance!
Thanks in advance!
i have only owned 1 2 stroke so i dont know.
if it were me i would drain the tank and the bowles.
add new fuel, try to lightly kick it over, make sure nothing is seized.
i would probably add a new plug, clean the filter and get some starting fluid and try and start it.
if it wouldnt start i would clean out the carb. then try again.
Originally Posted by danger k
I didn't drain it or flush the system or anything, but it was run down to pretty much empty.
Great, thanks for you guys help! One other (probably dumb) question: would I add the fuel stabilizer straight into the freshly filled tank, or mix it when I'm mixing the gas/oil?
I'm hoping to get to it this weekend, so I'll let you know how it goes...
Thanks again!
Thanks again!
Honestly? Fresh gas, clean the plug, and see if it starts. Worst case scenario you'll need to clean the carbs. I'd also put some Seafoam in the gas.
Thanks again!
Thanks again!
Ok here you go:
For your purposes this will be fine
Clean carburator(disassemble and clean out every jet with air or needle)
Take off gas tank and clean the filter and also wash out the tank with some gas
replace spark plug
Lube all pivot points
Clean air filter and airbox
check reeds for wear since the KDX200 is a 2 stroke I believe
check power valve and clean carbon from that
replace coolant
lube chain
lube all cables
(If I were you I may just rebuild the engine and everything will be apart anyways you might as well depending on how much time you have on the top end)
Anyways last but not least change the gear oil and bleed the brakes
Mix up some fresh gas and fire it up!
Now if it was me I would do what I am doing this weekend!
My CRF250R is getting torn all the way down with the exception of the motor. I am just going to shim the valves because I threw in a new top end w/ valves a few rides ago. So my bike should be in a million pieces all over the garage floor this Sat. Complete rebuild for the summer. That way I can clean everything and inspect stuff for wear.
I'm sure you don't want to go through all that I mean I work at a motorcycle dealership in the summer so I am a guru with these things
Here's me and the bike
replace spark plug
replace coolant
lube chain
lube all cables
Originally Posted by CRF250rider1000
Ok here you go:
replace spark plug
replace coolant
lube chain
lube all cables
replace spark plug
replace coolant
lube chain
lube all cables
I told you I am a freak when it comes to bike maintenance
Maintenance? I call that a complete tear-down and rebuild! Although I have been wanting to do it lately to my uncles' 1964 Piper Cherokee. Has a Lycoming O-320 4-banger (320 c.i. opposed cylinders) built back in 1963 and has had nothing but oil changes and spark plug replacements and has about 2,000 hours on it. Thats a lot for an airplane engine for you non-flyers out there.
I'm not familiar with airplane engines but sounds like it's time for a rebuild with 2,000 hours on that engine.So it's called a rebuild eh?
Normally it gets a fair amount of stuff done to it each week when I am racing, but right now it just needs to be overhauled since last season. I am at college and will be back riding soon so here's an opportunity for me to get it ready to go for the season. I like to make sure everything feels pretty new when I ride or else it just doesn't feel right you know. The bike should be looking good and in great shape after this weekend except for the darn shrouds. Those suckers get so beat up from me grabbing the bike. My number plate decals are also about close to wearing through. Oh well I'll just fix stuff as it needs it since that is cosmetic. I hate a dirty bike or truck though I'm sure a lot of you are in agreement there.
