Home Audio/Visual questions
Old Dec 19, 2007 | 11:20 AM
  #31
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
Ohh a junction box... You still have to snake the wall, I see now!
I was thinking a channel that you cut a strip out of the sheetrock/drywall, insert the channel, lay wires, replace piece that you cut out, mud in the seams and paint to match.
I was thinking damn thats a lot of work, I'll just snake the walls....
Old Dec 19, 2007 | 12:10 PM
  #32
turtle313's Avatar
What is HDMI 1.3b? HDMI.org doesn't even have any information on it. They only have specs up to v1.3.
Old Dec 19, 2007 | 01:05 PM
  #33
Wookie's Avatar
Yup, it's like a junction box for adding stuff once the house is built. Then get a blank faceplate and cut a hole just big enough for your cables to stick out. Fishing the cables through internal walls is easy as long as you cut the holes in between the same two studs. When I installed my TV, I added all of the cables that I figured I would need and just coiled the spares up behind the TV. So the TV is flat against the wall without a cord in sight. If I need to add something I just tilt the TV out and plug a spare cable in. I doubt that I will need these though. I have a HDMI between my receiver and TV and the Receiver has HDMI inputs.
Old Dec 20, 2007 | 12:44 AM
  #34
PSS-Mag's Avatar
Yea couple of my headers have extra holes in them where I miss calculated... added... done something wrong and missed the cavity between the studs that I was wanting to be in. :o
They are in the attic, no one will ever know...... except of course the ones who read this!
