Suspension Lowering (Plano/Dallas Area)
I liked it b.c it was cheap, and i dont like huge chrome tips, and then the sound grew on me
Before cats were gutted, following friend, drivers window down
http://s21.photobucket.com/albums/b2...omaxsounds.flv
After 2 cats gutted, sitting revving
http://s21.photobucket.com/albums/b2...t=MOV00113.flv
After 2 cats gutted, Highway cruise + 100 run
http://s21.photobucket.com/albums/b2...t=MOV00098.flv
Night time highway cruise (after 2 cats gutted)
http://s21.photobucket.com/albums/b2...t=MOV00362.flv
I saw where you were talking about getting the top bolts out. shouldnt be an issue. What about removing the spare? would I still not be able to get at the bolts?
Thanks,
leave the spare, you need the spare to add vertical space so the jack doesnt top out. Actually lay the 2x4 on the spare, and jack the spare and truck up!
you wont have a problem getting the bolts out with spare on, just put the bolt up against the under side of the bed, slides right out.
-Patrick
-Patrick
Thanks,
-Patrick
-Patrick
another question fo you have 4 or 2 cats on your truck? and if you have 4 did you hollow out all 4?
Originally Posted by dinty
Thanks Patrick, I probably would have gotten stuck on that part...saved me from cussing
<--- clickyand i hollowed out the two fronts (aka pre cats) originally had four, have 2 main cats still, didnt throw any codes b.c the O2 sim is after precats, and after main cat. So the computer only monitors how the rear main cat is filtering the exaust.
drop shackle how to, with pics
<--- clicky
I have read where I can get to hi-flow cats to replace my 4 existing ones...would I need the 02 sim???
very cool patrick. that is even better.
i see youve got an 2002, you should be able to gut precats, and do two highflows, and still not need sims
you shouldn't need sims if you get high flows,
