Dell laptop help
Old Feb 1, 2007 | 11:41 PM
Budha05STX's Avatar
Red face Dell laptop help
I have a Dell Inspiron 2650 (yes I know it's old but it still works for me :o ). Anywho, the keyboard went out on me; My question is, is it just a matter of replacing the keyboard or is it something else (like the software)? Is there any way to check? btw, I'm on the laptop right now w/ a regular keyboard from my desktop plugged in and the touchpad/mouse buttons work. Any help would be appreciated.
Old Feb 1, 2007 | 11:48 PM
F150FXOnline's Avatar
Im not to familiar with that model but work on Dell products. All the laptops Ive worked on C600,C610,D600,D510,D620 Latitude Laptops ect you just replaced the keyboard and its usallay very easy to switch out.
Old Feb 1, 2007 | 11:52 PM
Budha05STX's Avatar
So that should fix it?
The fact that I'm able to plug in an external keyboard and have it work means it's not the software, right?
The thing was working one minute and not the next.
Thanks for your help.
Old Feb 2, 2007 | 12:29 AM
OK lets start over...so none of your keys on the laptop are working? Im not sure if Ive seen all the keys go out at one time but not saying it couldnt happen and still be the keyboard. I would feel better if only some keys went out to be the keyboard. Reason being it could be something on the board thats went out not letting the keyboard work. Again Im guessing on that and still think replacing the keyboard would fix it. Have you tried rebooting your laptop? If not please do. Also I would take the keyboard apart and make sure everything looks plugged in all the way and reseat the connection. The turn it on again. When you hit any of the keys on the board does it make a beeping sound or any response at all?
Good Luck!
Old Feb 2, 2007 | 12:34 AM
Budha05STX's Avatar
Good Luck!
Correct, none of the keys work. The only buttons working are the power, touchpad, and the 2 "mouse" buttons. I've rebooted it 4 times already with no luck. No beeping or any type of response when hitting the keys.
Tomorrow I'll crack it open and take a look.
Old Feb 2, 2007 | 01:16 AM
whitecrystal1's Avatar
Mine went out on me (Inspiron 9200). I called Dell about it because mine is still under warranty. The guy I spoke with ask me to pop the trim panel off right above the keyboard. Then to take the two keyboard mounting screws out and check the connector. I found mine connector came out. After I plugged it back in it's been working great. Check it, if that's not it, at least there cheap and easy to replace.
Old Feb 2, 2007 | 01:40 AM
Budha05STX's Avatar
Sweet!!! I did that real quick and bammm!!! It worked. Thanks.
But I must have wiggled something else loose now cause it won't acknowledge the AC cord as being plugged in. Stand back, I'm going in again.
Old Feb 2, 2007 | 01:46 AM
When that happened to mine the mother board had to be replaced. That 100 extended 4 year warranty I bought was well worth it. I've also had a fan and hard drive replaced.
Old Feb 2, 2007 | 01:51 AM
Budha05STX's Avatar
I got it....loose connection at the brick/power inverter thingy. :o
Anywho, thanks for the help.
Old Feb 2, 2007 | 09:34 AM
vader716's Avatar
Congrats...Your A+ Certification is in the mail.
Old Feb 2, 2007 | 10:27 AM
jamzwayne's Avatar
OOOOOOH...so it's like that?
I don't wanna buy a wireless router, so I loose my cert, and Budha fixes his keyboard, and he gets one?
WTH
Old Feb 2, 2007 | 11:02 AM
Budha05STX's Avatar
whoooooo hoooooo, I get my cert.
That and a $1 will barely get me a small coffee.
Old Feb 2, 2007 | 12:06 PM
akheloce's Avatar
WTH
dont worry, it's just A+... you study reeel hard and get wun, and you could get a minimum wage job at best buy.
