Need SERIOUS HELP with my refrigerator, PLEASE
Old Oct 21, 2006 | 02:09 AM
cskrmetti's Avatar
Arrow Need SERIOUS HELP with my refrigerator, PLEASE
My refrigerator has stopped cooling completely. I know for a fact that the evaporator/condensor fan is not working. I am afraid that this might have caused my compressor to overheat and fail. Does anyone know how to test a refrigerator compressor to see if it works? I don't mind replacing the fan ($40-$60), but the compressor is around $200 and lots of hand labor in a tight area. If I have to spend 40-60 I will but at $250+ I will go buy a new one. The refrigerator in quesiton is a Maytag Performa. I'm hoping there are some Appliance Repair guys on here or someone who can point me in the right direction. Please help, my groceries are on ice right this minute.
Old Oct 21, 2006 | 02:19 AM
snappylips's Avatar
A lot of fridges don't even use condenser fans, just the coils on the back or bottom. The evaps. all use fans though. Do you have power at the fan motor? If your evap fan is definitely toast, then the compressor probably ran itself dead. Any blown fuses? Resetable circuit breakers? Have you tried changing the setting on the inside temp. controls? Tried unplugging and replugging?
Old Oct 21, 2006 | 02:23 AM
snappylips's Avatar
Forgot about the comp. test.
If you have a voltmeter, check for voltage at the comp. connector. If you have voltage, and it's NOT scorching hot, and NOT running, it's dead. If it's incredibly hot and voltage is present, let it cool and try it again.
If you have a manifold set, hook it up and check for low/high pressure readings. (Some systems don't have any service fittings installed at all)
SL
Old Oct 21, 2006 | 02:43 AM
MPSchenck's Avatar
...Maytag Performa...
Better off to buy a new unit. I worked for Maytag 4 years before their buyout by Whirlpool, and the Performa series products have proven to be horrible for no cool compressor replacements.
Old Oct 21, 2006 | 12:35 PM
cskrmetti's Avatar
Yeah I just found out that the Performa Series are made in Mexico and are not really the same as other Maytags. I know that the compressor is getting power, I can hear it humming and it was getting warm until I unplugged the fridge. The fan motor died for some reason. When the fridge was plugged in the fan would not rotate. If I started the fan by hand, it would rotate very slowly for a minute before coming to a halt. The fan is not completely siezed up, but it definately is not working right. The fan costs $70 with shipping so I think it might be worth a try, rather than dropping $700+ on a new fridge.
Yes it is an EVAP fan not a condensor fan
Old Oct 21, 2006 | 03:34 PM
cskrmetti's Avatar
Update.....
I manually turned the fan for a while and now it spins freely. I will still likely replace it because it will surely not hold up. So that works for now.
I tested the compressor for continuity, the start, run, and common all have continuity with each other. I tried to test the overload capacitor and got an OL reading. I also tried to test the relay and only got a continuity reading from two of the three. It seems that the run and start have a continuity of around 8-9 ohms whereas both came back with an Open Loop reading when tested against the common.
With that being said, a good reading from my compressor indicates that it is still good (I think). Apparently the relay and the overload capacitor need to be replaced.
Anyone care to chime in here. By the way, if it sounds like I know what I am talking about, don't worry. I have no idea.
Old Oct 22, 2006 | 04:30 PM
SuperSport1985's Avatar
Quit farting around get a new one.
Old Oct 22, 2006 | 08:33 PM
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
Sounds like the bushings or brushes in the fan motor.....
Depending on the casing..... this can be created if the motor casing screws have loosened...... that would be a free fix if that is the case. but you have to dissassemble to realign the brushes......
For less than $70.... I'd see if an electronics store could rebuild the motor for it.....
