Reverse Camera problem..HELP!!!!!
Old May 26, 2006 | 08:14 PM
  #31
Zaairman's Avatar
Maybe you're just an idiot
Shoulda gotten the tow package, it makes things MUCH easier.
I know, I'm being an ***
Old May 26, 2006 | 08:28 PM
  #32
BREWDUDE's Avatar
Yes you are!!!!!!!!
See if I'm around next time you need help...
This is kickin my ****..I know its gotta be something stupid and easy..
damn I need a beer..I'm outta here.
BREW
Old May 26, 2006 | 08:52 PM
  #33
Quintin's Avatar
The connector you're looking for is on the driver's side of the transmission at the MLP (manual lever position) switch. The shift cable attaches to a little lever that has a nut on it that holds it onto the manual lever on the transmission and the MLP itself. I'll try to find you another reverse reference, but that's the best one I can think of right now.
Old May 27, 2006 | 11:13 PM
  #34
BREWDUDE's Avatar
Quintin...any luck with finding another spot to tap into??
Let me ask you this....the dark green / yellow wire Im tapped into...where does that connect to in the fuse box? I'm wondering if I pull the power for the head unit right where this wire connects to the fuse box or relay, I may have a better chance of getting full power and not have to worry about the voltage drop. What do you think?
BREW
Old May 27, 2006 | 11:31 PM
  #35
lees99f150's Avatar
why not get the power from any good source and have it feed the camera via a relay triggered by the reverse circuit.
Old May 27, 2006 | 11:52 PM
  #36
6T6CPE's Avatar
Originally Posted by BREWDUDE
Well I'm just about to give up on this crap. I cant find the connector you're talking about on the transmission and to be totally honest, I'm not sure I want to mess with any connectors or wires on the tranny. The only thing thats labled "reverse lamp relay" is that fuse #14 which is hot at the fuse all the time. Maybe it should be that way and I'm just retarded. There's gotta be another way.
I did some testing tonight and found that the voltage drop across that wire when I hit the brakes is less than 1 volt. Cant I just put a capacitor in line between the power source I am tapping into( dark green / yellow ) and the head unit? Would that be ok? What size capacitor should I use if its possible. I dont want to screw anything up in the wireing or risk damaging the headunit, so if the capacitor idea is a no go and I cant find another wire that hot in reverse.....The only thing this camera is gonna see is the bottom of the ocean.
Quintin, any ideas?
Anyone? I can't believe I'm the only one whos had this problem.
BREW
Now I know why Caine has that hopeless, puzzled look. He's got the look of "Here we go again. Another project! Guess we'll be gettin another new truck next year"
Old May 28, 2006 | 10:44 AM
  #37
Zaairman's Avatar
I think most of BREW's projects can be summarized by "Hold my beer, watch this"
Old May 29, 2006 | 10:23 PM
  #38
BREWDUDE's Avatar
Well this project wasn't and I think that was the problem. So after checking it out with my meter, the help of Quintin, Lees99f150 and PSS-MAG (around 1am this morning) I decided to go with a relay..oh, and a few beers before I started
The relay did the trick. I pulled the power to the relay right out of the fuse box, grounded it right there at the "easy to get to" ground stud and used the dark green / yellow wire to trigger it. ( The same wire I'm using to power the camera ) It works great now. No voltage drop, so the screen stays on all the time now. Its awesome, I like it.
Thanks to everyone for the help...even you guys in the peanut gallery, you kept me smiling. I'll get some pictures of it later.
BREW
Old May 29, 2006 | 10:28 PM
  #39
Quintin's Avatar
The relay wasn't my idea, and it was a good one, I wish it was mine.
Good to see you got things worked out nonetheless.
Old May 29, 2006 | 10:45 PM
  #40
lees99f150's Avatar
i said to try the relay method in post #10 but i guess brew wasn't listening then, i guess by post #35 he was getting a little more desperate.
Good to See it work out for ya brew. i'd like to see how it looks in the cab.
remember you can do just about any wiring and switching with the Bosch relays.
Old May 29, 2006 | 10:56 PM
  #41
BREWDUDE's Avatar
Well I gotta tell you guys..I can be a little stubborn at times..ok, alot stubborn. I dont like to add to many switches and relays, resistors, capacitors, or cut to many factory wires...so it takes a little longer for me to get to that point. Since the camera was danggling out the window as I drove past the ocean yesterday, I decided to give it one more try...
I'm glad I did. I'll get pictures of it tomorrow during the day and at night and post them up here...
Thanks again guys.
BREW
Old May 30, 2006 | 12:27 AM
  #42
6T6CPE's Avatar
Thanks again guys.
BREW
Aw shucks! It was nuttin!
