Reverse Camera problem..HELP!!!!!
Old May 24, 2006 | 10:06 PM
BREWDUDE's Avatar
Originally Posted by Quintin
Just to see if it works, I'd strip the wire back, pull the fuse and jam the wire between the fuse and the terminal in the box. If it does work, I've seen some pretty decent looking fuse taps that are probably available at your friendly neighborhood AdvancepepautoboysO'ReillysZone that'd prevent you from having to hack your harness up any more than necessary.
Cool Cool...thanks Quintin, you're the man. I'll give it a try tomorrow. I'm dying to get this thing in, but I refuse to cut a hole in my bumper until its working 100%. Thanks again, I'll let you know how it works out.
BREW
Old May 24, 2006 | 10:11 PM
Quintin's Avatar
Don't thank me just yet, I ain't got a clue whether this'll work or not. But we'll figure out something if it doesn't.
Old May 24, 2006 | 10:21 PM
BREWDUDE's Avatar
..we'll see.
BREW
Old May 25, 2006 | 06:05 PM
BREWDUDE's Avatar
Well...no luck. #14 is hot all the time. I also checked #10 and thats hot all the time as well. Im losing my patients with this thing fast. Any other ideas?
BREW
Old May 25, 2006 | 06:30 PM
Quintin's Avatar
Sit tight and lemme look over the diagram some more.
Old May 25, 2006 | 06:49 PM
BREWDUDE's Avatar
Oh, I'm tight..my teeth are clenched together, my fists are in *****, and my head feels so tight I think its gonna explode.....
HAHA..thanks man...I'll be here.
BREW
Old May 25, 2006 | 09:31 PM
Quintin's Avatar
Okay, shimmy under the truck and try at the MLP switch on the transmission, connector C167. If you're facing the opening of the connector with the locking tab pointing up, it'll be the second pin from the left on the bottom, circuit 1043, should be a DG/YE wire.
Old May 25, 2006 | 10:08 PM
BREWDUDE's Avatar
Is that the same DG/YE wire I have in my passanger side door sill? If so, thats the wire I'm tapped into for power to the camera. And if I hook up the head unit power to the same wire I get the feedback...
BREW
Old May 25, 2006 | 10:10 PM
Quintin's Avatar
I don't think so, this wire is after the MLP and provides power to the reverse lamp/trailer tow relay, so it should only be hot when in reverse. If it was hot constantly, the reverse lights would stay on all the time.
Old May 25, 2006 | 10:17 PM
BREWDUDE's Avatar
Ill give it a shot tomorrow, but one question...what if I dont have trailer tow?
BREW
Old May 25, 2006 | 10:49 PM
Quintin's Avatar
Then it'll be labeled as a "reverse lamp relay." The wiring still provides power to the reverse lamps regardless of whether it's equipped with the trailer tow package or not.
Old May 25, 2006 | 10:57 PM
BREWDUDE's Avatar
OK..sounds good. I'll check it out tomorrow and let you know. Thanks man.
BREW
Old May 26, 2006 | 10:03 AM
6T6CPE's Avatar
Backup Camera for an F150? Whatever happened to using the mirrors or turning around? Maybe hire an illegal to be a Spotter for ya! Or maybe it's time to let Caine drive for ya!
Old May 26, 2006 | 10:44 AM
KSUWildcat's Avatar
Have you sat in the 04+ F150? If you are in the driver seat, it is no mans land back behind the tailgate. I've easily lost a Geo or two back there!
Old May 26, 2006 | 08:03 PM
BREWDUDE's Avatar
Well I'm just about to give up on this crap. I cant find the connector you're talking about on the transmission and to be totally honest, I'm not sure I want to mess with any connectors or wires on the tranny. The only thing thats labled "reverse lamp relay" is that fuse #14 which is hot at the fuse all the time. Maybe it should be that way and I'm just retarded. There's gotta be another way.
I did some testing tonight and found that the voltage drop across that wire when I hit the brakes is less than 1 volt. Cant I just put a capacitor in line between the power source I am tapping into( dark green / yellow ) and the head unit? Would that be ok? What size capacitor should I use if its possible. I dont want to screw anything up in the wireing or risk damaging the headunit, so if the capacitor idea is a no go and I cant find another wire that hot in reverse.....The only thing this camera is gonna see is the bottom of the ocean.
Quintin, any ideas?
Anyone? I can't believe I'm the only one whos had this problem.
BREW
